Results 1 to 1 of 1
Thread: Shipman 520 travel stop pawl
15th Oct 2022, 07:29 PM #1Philomath in training
- 6,541
I have a Jones and Shipman 520 and I was approached by a new member who had seen my posts on it asking for some dimensions for a part. My better half and I have been caught up in the Optus thing, so we are a little wary about sending things to unknown emails at the moment.
Instead, I'll post some drawings and photos here.
The pawl flicks into a groove on the feed wheel; there is a two position ball detent that holds it. The photo shows the out position. In the in position, the end engages with a stop in the groove on the wheel
The ball is 3/16" diameter, the spring is 3/8" long, 5/32" OD and is 5 turns of 0.020" wire. Nothing critical there - it just holds the ball in a dimple on the body casting.
The two most complex parts are the shoulder screw and pawl, drawn below.
Surface Grinder Travel Less than Mag Chuck
By TommyGMachining in forum METALWORK GENERALReplies: 10Last Post: 20th Jan 2020, 07:24 PM -
Ratchet and Pawl source
By SurfinNev in forum METALWORK GENERALReplies: 10Last Post: 10th Dec 2019, 08:33 PM -
Micrometer Travel Stops
By Anorak Bob in forum METALWORK GENERALReplies: 28Last Post: 5th Mar 2015, 09:35 PM -
Bantam Topslide Travel
By electrosteam in forum METALWORK GENERALReplies: 1Last Post: 17th Sep 2009, 09:24 AM
