Results 31 to 33 of 33
6th Sep 2022, 12:35 AM #31
I did send it and sent one for your first PM as well. I assume you never received either one. Strange but the messages were not saved to my sent folder either. I must be doing something wrong. I am part of a few forums but I guess MWF works differently. I will pay more attention to the options next time.
7th Sep 2022, 12:33 AM #32
I was passing by Gardner Bearings in Cavan and thought I should pick up the belts and based on info shared earlier in this thread I picked up sizes A21 and A24.
Unfortunately they do not seem to be the correct combination as there is no way the A21 will slip fit over the pulleys.
I will need to measure the belts required and make a run back to Gardner Bearings on Friday since Im tied up in the CBD for the next couple of days.
9th Sep 2022, 11:20 AM #33
Gardner Bearings was kind enough to replace the A21 belt for a A25 (no questions asked). I did not shop around for prices but my experience dealing with them has been very good.
So as it stand, I decided to go with a A24 between the spindle and center/idle pulleys and A25 between the center/idle and motor pulleys. This gave me enough tension on the belts and the motor tensioner is currently a bit less than half way along its travel.
This combination of belts sizes should make belt changes fairly hassle free and I have enough adjustment left on the tensioner to accommodate for any belt stretch with usage over time. These may not be standard for other drill presses out there as I have no idea if the pulleys are standard sizes on this drill press.
Drill press speed optimisation
By Michael G in forum METALWORK GENERALReplies: 45Last Post: 29th Jul 2021, 11:50 AM -
waldown drill press hi speed
By eskimo in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 9Last Post: 8th Oct 2018, 05:28 PM -
GMF Betts 12 Speed Drill Press Tidy Up
By Burnsy in forum METALWORK GENERALReplies: 36Last Post: 8th Dec 2014, 12:40 PM -
Herbert High Speed Bench Drill restoration
By mgtoolmaker in forum METALWORK GENERALReplies: 23Last Post: 9th Aug 2014, 06:07 AM -
Switching 2 speed motor for drill press
By Bryan in forum METALWORK GENERALReplies: 3Last Post: 28th Dec 2011, 07:05 PM
