Results 1 to 8 of 8
Thread: Klopp Shaper Model 1000H
23rd Jan 2022, 09:00 AM #1
Novice
- Jul 2012
- Marrickville NSW
- 20
After a quite a few years in storage and other competing projects the mates big (and I mean big) Klopp Shaper got its first run. It still needs a further clean up and service. As usual it did not come with a manual and I am chasing one as it has an issue with the quick traverse function i need to sort out. It should be handy to resurface the odd anvil or swage block. YouTube video of it running.
23rd Jan 2022, 10:03 AM #2
Most Valued Member
- 55
- 2,163
Awesome!
Makes my 350 model look like a miniature!
4th Feb 2022, 08:27 PM #3
Most Valued Member
- 70
- 5,148
Hi Fargo, Cutting Edge Engineering up in Brissy has the same machine, and he has a copy of the manual, he may make a copy it for you.
His machine went into the shed today, from being in storage also. The machine is missing the reversing cable for the clapper box, so if yours has it, you might take the details of it and help each other out with a swap.
https://www.youtube.com/watch?v=fNH8ztBgd30
HTH
5th Feb 2022, 10:11 AM #4
Novice
- Jul 2012
- Marrickville NSW
- 20
Thanks Kryn, I have been in touch re the manual and the Clapper lift cable.
Cheers Hugh
6th Feb 2022, 08:09 PM #5
future machinist
- Mar 2008
- nowra
- 1,592
Man that's a beast. Is it the machine in Marrickville ? Would love a sticky beak. Just around the corner
Andre
7th Feb 2022, 06:24 PM #6
Novice
- Jul 2012
- Marrickville NSW
- 20
I wish, its in the mates yard at St Marys.
Cheers Hugh
13th Feb 2022, 11:00 AM #7
Novice
- Jul 2012
- Marrickville NSW
- 20
Kurtis at Cutting Edge Engineering kindly sent me a copy of the manual. Confirmed that there is an issue with the the rapid traverse function.
Cheers Hugh
1st Aug 2022, 07:01 PM #8
Novice
- Jul 2012
- Marrickville NSW
- 20
Klopp 1000H Shaper update
Viewing of CEE Klopp video and perusal of the manual generously provide by CEE confirmed there was an issue with the quick traverse function on Jim’s machine. The first step was to remove the quick traverse motor and check that the drive key on the motor shaft was not sheared and the motor tuned in the correct direction. Both of these items were correct. The next item in the quick traverse drive train is the worm wheel shaft and worm. To access this component required the strip down of the feed drive mechanism.
On disassembly it was apparent that the unit had at some point had suffered water ingress with minor damage to some components. Once the numerous taper pins had been removed and drive unit disassembled access was gained to the final component in the quick traverse drive train, the worm wheel. The worm wheel rides on the on the main feed shaft and when the shaper is operation is held stationary by the worm wheel shaft. The worm wheel has a recess machined in the bore which has a spring loaded sprag tooth (item 190) that rides on the shaft. When the quick traverse motor is actuated the worm wheel is rotated and the sprag tooth engages in a recess machined in the drive shaft and rotates the feed shaft.
On disassemble the sprag tooth was found to be seized in the retracted position, with the springs corroded and broken. This was the cause of the lack of quick traverse function. Replacement springs were sourced from the Mick Moyles in Summer Hill, a fantastic resource and one of the last “brick and mortar” second hand machinery dealers left in Sydney and luckily for me close by. After a thorough clean of components replacement of a roller bearing, needle roller bearing and sleeve, and the a fore mentioned springs the feed unit was reassembled and installed back on to the shaper for test.
The sprag tooth can be seen in the image below.
Link to YouTube video of the test of the quick traverse function and tool lift operation. https://youtu.be/5yjjKC16xMA
Cheers Hugh
Perfecto model no.1, 5" hand metal shaper nos
By Silversprings in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 14th Nov 2021, 08:19 AM -
need help to dismantle late model Shearaton 9" model A to transport home
By ajbvicau in forum SHERATON AREAReplies: 5Last Post: 3rd Jun 2021, 01:17 AM -
Klopp shaper info
By Ajax01 in forum METALWORK GENERALReplies: 12Last Post: 2nd Dec 2019, 11:26 PM -
Adventures with my Klopp shaper
By OxxAndBert in forum METALWORK GENERALReplies: 26Last Post: 6th Oct 2019, 12:30 AM -
Magazines in need of a home - Aust Model Eng, Model Eng, Model Eng workshop
By DarrylB in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 7th Mar 2018, 06:20 PM
