Results 1 to 1 of 1
Thread: Macson QC Gearbox knob
8th Oct 2021, 10:57 PM #1Senior Member
- Feb 2014
- Werribee, Melbourne
- 178
During the extended COVID break here in Melbourne I have been twiddling my thumbs on various overdue tasks on the old Macson (1946 17") and in order to remove the carriage/crossfeed drive shaft I needed to remove the QC gearbox. What started as 'just a clean-up while I had it out' has turned into a bit more detailed teardown / clean than planned.
The Macson came with a damaged QC gearbox ratio selector knob - the bakelite end was completely missing leaving a steel centre stub that is fitted to the sprung loaded pin with an off-centre tapered pin. The knob belongs to the gear selector seen in the foreground here.
I didn't have the presence of mind to take a photo of the steel piece before fitting my substitute knob to it but that piece is shown in this picture I copied from an eBay ad.
It is a small steel bar that had bakelite formed around it and this was anchored in a shallow machined groove.
I knocked up a copy of the knob on the 3D printer - it is made up of two main sections with a split collar arrangement inserted in the lower section to clamp into the groove. This required a bit of faffing around as there is only about 6/7mm of the steel section in the knob and given the tapered pin was fitted off-centre it seemed less fiddling than trying to make a different steel piece.
The replacement was printed in black PLA that has been sanded and given a bit of polish and it does match an original fairly well (original bakelite on the right) so I am very happy with the result.
In the unlikely event someone else needs to make one of these I am happy to share the .stl files.Last edited by Ray-s; 8th Oct 2021 at 11:00 PM. Reason: Typo
Stuck Lock Knob Bolt - Tablesaw
By FlaminGunz in forum METALWORK GENERALReplies: 7Last Post: 19th Sep 2021, 05:26 PM -
Ball knob cutter
By Grnman1147 in forum THE HERCUS AREAReplies: 7Last Post: 4th Jun 2020, 06:44 PM -
In Defence of the Plastic Knob
By Anorak Bob in forum METALWORK GENERALReplies: 12Last Post: 4th Jan 2011, 02:01 PM -
Small knurled knob
By Tiger in forum METALWORK GENERALReplies: 10Last Post: 27th Apr 2010, 12:51 PM -
Hercus 4-way tool post knob?
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 25th May 2008, 07:00 PM
