Results 1 to 5 of 5
Thread: Drill Press
    Nov 2008
    Canterbury UK
    67
    4
    Default Drill Press
    I hope this is the correct place to put this and also I normally spend time on the woodworking site.
    Anyway I am wondering if someone may help recognize this drill press. I have tried on some of the UK website with no luck so am spreading out around the world with hope someone has heard of this machine.
    It is labeled KIM it is also labeled on the motor as KIM Induction Motor.
    The wooden handles are of my own making as there were only two on it when I got it I also find these very comfortable to use
    DSCF0336 (600x800).jpgDSCF0333 (580x800).jpgDSCF0339 (800x600).jpgDSCF0335 (800x600).jpg
    "He who has not turned anything has not yet had fun"
    http://youtu.be/sMRDsHxNYKw
    http://youtu.be/Y92wP_SCbdE
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    I don't know of KIM as such but from the styling and finish work, I would suggest that it is a Asian import that has been made under many names.
    7,188
    Not sure I would call it antique or vintage.
    Looks almost identical to one we had at the mens shed that I was asked to look at as the switch which was damaged and I replaced it with a no-volt type.
    It also had the quill handles replaced, but in this case with bare long bolts
    It made a bit of a racket - i suspect the bearings needed replacing.
    From memory it had quite a high lowest speed so I recommend it be retired as we had 3 other drill presses that were in better shape.
    Nov 2008
    Canterbury UK
    67
    4
    Thank you both it seems this may remain a mystery as it does not matter how many searches that I do bring up zero results unless someone know how to search better than I can as I am not the best at computers and wording things for searches
    I think you could be right it is 8 years to young to be vintage(depending on how you define vintage age).
    Apr 2018
    168
  1. Paper drill from converted drill press
    Last Post: 16th Mar 2020, 07:26 PM
  2. Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
    By bwal74 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 10th Feb 2019, 03:11 PM
  3. Drill Press JBS
    Last Post: 14th Feb 2018, 06:59 PM
  4. Any one know what drill press this is??
    By xXvapourXx in forum METALWORK GENERAL
    Last Post: 12th Sep 2012, 11:14 PM
