Results 1 to 10 of 10
    Nov 2017
    Australia
    35
    Default Parkanson Powered Hacksaw
    G’day everyone I’m wondering if anyone has a manual for this Parkanson powered hacksaw? If you have one of these more modern ones what speed is it running at roughly?
    You can see it running here https://youtu.be/knXdlCh65F8
    Mar 2017
    65
    221
    I have the same machine. I'm restoring it. Came with 3 phase motor, so I'm installing a VFD to run of 240 single phase. The hydraulic lift seems very worn, but the rest looks in very restorable condition. So, some work needed to re-manufacture the pump/lift mechanism. Someone has replaced the coolant pump with a stand alone 240v unit, so that's not a problem.
    To your question...sorry I don't have a manual. I searched on line and found very little on this model.
    Damn good looking saw, I reckon. Strong and should cut straight. Looking forward to finishing the resto and putting her into service.
    Cheers, Tony
    Sent from my SM-N976B using Tapatalk
    Nov 2017
    Australia
    35
    Quote Originally Posted by Silversprings View Post
    Cheers, Tony
    Thanks Tony. Yeh I just swapped out the 3 phase motor for a single phase one yesterday. My hydraulic ram was bent in half and had to make a new one but it works great now. Good luck with the resto
    Sent from my SM-A217F using Tapatalk
    Nov 2017
    Geelong, Australia
    57
    2,671
    I had one for a while, but sold it last year when I got my big horizontal bandsaw.
    Here's mine running https://www.youtube.com/watch?v=tHEMVzLvJjM
    Looks to be about the same speed as yours.
    Nov 2017
    Australia
    35
    Awesome thats a relief haha. Just seems fast but good to know its not. Looks like your saw crank spins the opposite way to mine the arrow on yours is anti clock wise and mines clockwise... weird variation haha
    Nov 2017
    Geelong, Australia
    57
    2,671
    Nothing to say that mine is turning the right way. It was definitely cutting on the pull stroke and lifting on the return (push stroke). That was how I connected the motor up - definitely worked well but I’m not sure if it’s “correct”.
    Nov 2017
    Australia
    35
    Mine cuts on the push stroke. Dont know if theres a right or wrong as long as it cuts. Cutting on the pull stroke on a powered hacksaw does make more sense to me though
    Apr 2019
    Adelaide
    596
    My PHS is almost identical to yours (hydraulic lift cylinder looks a little more beefy on mine). Works great but I still need to put a seal of some sort on the lift plunger. Mine runs the same speed as all of yours. Cannot recall if it cuts on the push or pull stroke.
    I have a thread on here somewhere with the plumbing of the hydraulics if that helps.
    Nov 2017
    Australia
    35
    Quote Originally Posted by Mk1_Oz View Post
    Thanks. I had to make a cap for the hydralic ram and rebuild they're surprisingly simple. Glas the speeds the same it just seemed fast but good to know its not
    Nov 2016
    Gulfview Heights, Adelaide
    83
    I have the same machine, it has 3 phase motors for the main motor and coolant pump.
  1. Parkanson Power Hacksaw
    By Mk1_Oz in forum METALWORK GENERAL
    Last Post: 14th Nov 2020, 07:17 PM
  2. Parkanson power hacksaw
    By OxxAndBert in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 1st Oct 2020, 03:41 PM
  3. Parkanson Power Hacksaw 45 angle cut
    By TootsieB in forum METALWORK GENERAL
    Last Post: 23rd May 2019, 01:53 PM
  4. SOLD: PARKANSON Power Hacksaw
    By harty69 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 15th Jul 2013, 07:52 PM
  5. Parkanson power hacksaw
    By Dave J in forum METALWORK GENERAL
    Last Post: 18th Feb 2012, 08:09 PM
