Results 1 to 4 of 4
    Feb 2014
    Werribee, Melbourne
    178
    Default Rexman Bull Gear locking pin
    Does anyone know what the original retaining set-up was for a Rexman Bull Gear locking pin?
    This is an earlier, relatively small flat-belt model.
    I am helping a friend get one back into service and this (whatever it was) is missing. The screw to the left of the pin in the following photo has a cross-hole drilled in the head and that indicates perhaps some sort of spring. However, the pin itself has no grooves to locate it halfway out and can be pulled out completely so was it intended to be removed completely for back-gear operation and have something that folded over the back of the pin in normal operation?
    Any insight gratefully received.
    Dec 2014
    melbourne
    72
    G'day Ray-s, I have had my Rexman for 55 years and never run it in the back gears for the same reason your friends machine won't run...missing teeth.
    However the drive pin on my machine screws in and would have to be removed completely to use the back gears.
    Hope that is of use to your friend.
    Robert
    Feb 2014
    Werribee, Melbourne
    178
    Thanks Robert - that helps confirm what I suspected because I can't see a way to safely hold the pin in a disengaged position.
    Yes, there appears to have been destructive attempts to unscrew a very tight chuck backplate with three teeth on the back gear and one on the bull gear AWOL.
    The eccentric back gear shaft was also bent from this jiggery pokery.
    Both gears are cast iron on this model so I will have a bash at repairing the teeth - I have made a replacement eccentric shaft for the back gear.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    The gears may be able to be re ringed if repairs are ineffective.
  1. Magic bull gear pin trickery?
    By MosquitoGarage in forum THE HERCUS AREA
    Last Post: 30th Aug 2019, 09:18 PM
  2. Tight fit for bull gear ?
    By phelum in forum THE HERCUS AREA
    Last Post: 19th Dec 2013, 07:44 AM
  3. Hercus Model A Bull Gear
    By YarrD in forum THE HERCUS AREA
    Last Post: 23rd Jan 2010, 08:17 PM
  4. Gear tooth count on Back/Bull Gear.
    By pipeclay in forum THE HERCUS AREA
    Last Post: 6th Jan 2010, 11:56 AM
  5. Bull Gear Info From F.W. Hercus
    By steran50 in forum THE HERCUS AREA
    Last Post: 9th Dec 2009, 03:00 AM
