Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Hendey lathe
  1. #16
    Jun 2007
    sydney ( st marys )
    61
    4,500
    Near enough .00196"
  2. #17
    Nov 2007
    Near Rockhampton
    223
    Because the original metric cross feed dial has 500 graduations , 0 to 5mm ( .01 ) , my calculation is, the replacement 5 TPI lead screw means
    : 5 graduation marks = .002" . ??
    I think your calculations are correct for your 5 TPI screw.
    1rev = 0.2"
    500 div per rev = 0.0004"/division
    5 Div =0.002"
    I think pipeclay's results are for a 5mm leadscrew?
  3. #18
    Jul 2008
    near Warragul, Victoria
    3,401
    Default Holbrook
    I have a Holbrook T13 of 1940's era. Its similar in concept to the Hendey . I picked up these old machines when the market for old used lathes was in a slump.... few hundred bucks for the Holbrook.
  4. #19
    Jul 2008
    3,401
    Default Noises
    The Hendey 12 speed geared headstock is rather noisy , I suspect it has some dud bearings .I removed the top cover and poked around a magnet in the oil trough, picked up some small metal fragments , nothing too bad Could not find any obvious loose parts or worn gears or shafts . But with the gears in neutral and spinning the three shafts individually, this test reveals the bearings have that bad bearing 'rumbling' noisy sound .Maybe in its past the lathe has been run for a while without the correct lubricants or low oil.
  1. My Hendey and GMH
    Last Post: 14th Jul 2012, 11:58 PM
  2. Hendey factory tour
    Last Post: 16th Jun 2012, 03:10 PM
  3. Hendey wiring
    Last Post: 4th Apr 2012, 07:38 PM
  4. HENDEY is here
    Last Post: 17th Mar 2012, 08:30 PM
  5. Hendey 12 X 30 lathe
    Last Post: 29th Feb 2012, 12:51 PM
