Results 16 to 19 of 19
Thread: OMC Rotary Engine
8th Aug 2019, 04:29 PM #16
Got the engine back together today, got strong compression all good More work on the engine tomorrow. Took me a good six hours for this part of the build.
Resize of IMG_7510.jpgResize of IMG_7511.jpgResize of IMG_7512.jpgResize of IMG_7513.jpgResize of IMG_7514.jpgResize of IMG_7518.jpgResize of IMG_7515.jpgResize of IMG_7516.jpgResize of IMG_7517.jpg
17th Aug 2019, 04:01 PM #17
I screwed down the stator and stuck some high temp heat shield material on the steel cover and the charge coils, this should extend the life of the coils. i have started working on the Electricals, this is not my expertise, i need to read the manual again on how this system works and get it to sink in my head. I did find a electrical diagram looks similar to the wiring harness i got with one of the engines i have, will try with this out.
Resize of IMG_7529.jpgResize of IMG_7530.jpgResize of IMG_7528.jpgResize of IMG_7500.jpgResize of IMG_7523.jpgResize of IMG_7524.jpgResize of IMG_7525.jpgResize of IMG_7526.jpg
31st Aug 2019, 08:06 PM #18
I got quite a lot of work done on the engine, made a test stand and bolted the engine down on rubber mounts and i think i got the wring work out, still need to work on the exhaust system and a bit more work on the electrical system.
Resize of IMG_7539.jpgResize of IMG_7544.jpgResize of IMG_7540.jpgResize of IMG_7541.jpgResize of IMG_7542.jpgResize of IMG_7543.jpgResize of IMG_7545.jpg
16th Sep 2019, 02:42 PM #19
I was ready to do a test start on the engine today and now have a leaking fuel pump, the pump is brand new there is no O ring or gasket that seals the top. I may have to make up a seal and see if that works. I work out the electrical system i now have Spark when cranking the engine by the recoil starter. Also finished the exhaust system.
Resize of IMG_7555.jpgResize of IMG_7556.jpgResize of IMG_7557.jpgResize of IMG_7558.jpgResize of IMG_7559.jpg
Windsor engine
By azzrock in forum AUTO PARTS / Wanted, For Sale - HELPReplies: 21Last Post: 2nd Jan 2021, 06:46 PM -
Goggo Engine
By Goggomobile in forum AUTO RESTORATIONReplies: 0Last Post: 1st Jul 2016, 09:03 PM -
Stirling engine help
By xXvapourXx in forum METALWORK GENERALReplies: 14Last Post: 9th Jul 2011, 11:35 AM
