Results 1 to 7 of 7
16th Oct 2016, 07:52 PM #1Novice
- Aug 2016
- Qld, Australia
- 14
Need help identifying this cold saw.
Hi,
I bought this today and am looking for a manual to pull it apart to give it some TLC however I'm not 100% sure exactly what it is.
Any help is greatly appreciated
16th Oct 2016, 09:16 PM #2Philomath in training
The motor name plate has a model designation for an AEG motor. Based on that I looked up German Cold Saws and came up with Haberle as a brand. It will depend on age and blade size, but it looks much like a Haberle H 250
Haberle H 250 Cold Saw
16th Oct 2016, 09:19 PM #3Novice
- Aug 2016
- Qld, Australia
- 14
Came with 5 x 300 blades. There is no on off switch or speed switch at all.
16th Oct 2016, 09:27 PM #4Philomath in training
It's got a general resemblance to the Haberle line of saws - with a 12" blade it would be a H300. I would send off a few pictures to them and see what their thoughts are, remembering that previous owners may have modified it for some reason and that the design may have changed over the years, so the switch box on top could be a relatively recent addition. I've got some gear that the manufacturers said that yes it is one of theirs and can approximately date it but is a superseded design and can't supply much in the way of information.
HABERLE Cold Saws, Legacy Machines - perhaps a Brobo super 300?
MichaelLast edited by Michael G; 16th Oct 2016 at 09:30 PM. Reason: added bit
16th Oct 2016, 11:30 PM #5Novice
- Aug 2016
- Qld, Australia
- 14
I was actually leaning towards the brobo. Can you tell the blade speed from the motor tag? I'll be getting a vfd. Once I work out which one. I'll be cutting mostly 16mm bright bar and NB tube. Not much else.
Im pretty happy about getting it.
17th Oct 2016, 06:35 AM #6Philomath in training
Motor speed is 1390 revs per minute but there is a gear box in the way and I don't know the ratio.
17th Oct 2016, 11:25 PM #7Novice
- Aug 2016
- Qld, Australia
- 14
Turns out to be a Brobo super 300 from the late 70's ish (re badged Haberle). They said it should be a 2 speed unit however someone has modified it and rotated the motor 90deg. I'm going to fit a vfd so any kind of switch is really irrelevant.
Thanks for your help.
Identifying Aluminium
By Oldneweng in forum THE FOUNDRYReplies: 23Last Post: 18th Aug 2013, 10:33 AM -
Help in identifying my lathe
By moxonvee in forum THE HERCUS AREAReplies: 4Last Post: 26th Aug 2012, 10:46 PM -
Cold Saw Options: Triton, Cold Saw, Power Hacksaw
By Jarh73 in forum METALWORK GENERALReplies: 41Last Post: 2nd May 2012, 09:15 PM -
Identifying metals
By terry arnold in forum METALWORK GENERALReplies: 3Last Post: 24th Jun 2009, 05:23 AM -
Need help identifying these
By wannabe in forum METALWORK GENERALReplies: 14Last Post: 23rd Nov 2008, 09:47 PM
