Results 1 to 8 of 8
Thread: Hi, all.
2nd Aug 2021, 10:30 PM #1New Member
- Aug 2021
- The Rock, NSW, Australia
- 70
- 6
Hi, all.
Hi, all. This looks like a good forum to be on, lots of knowledgeable people with good advice.
Speaking of which (probably bad manners to ask questions on my first post, but I'm in a bit of a bind here), I was wondering if anyone could tell me if there are any issues with removing the apron on a Macson lathe similar to the one in this post: https://metalworkforums.com/f300/t20...t=macson+lathe
During a moment of inattentiveness, the operator failed to disengage the facing feed and the carriage hit the mount for the handwheel. The autofeed no longer works in either transverse or longitudinal travel. My main problem right now, though, is getting the apron off so the damage can be assessed. So, any hidden traps that I should be looking for?
2nd Aug 2021, 10:42 PM #2
Hi Bushranger,
Welcome to the MetalWork Forums,
There are lots of good people here who are supportive friendly and helpful.
Please take the time to navigate around the forums to view the varied and interesting subjects.
To do this, goto the the FORUM box in the top left hand corner of the screen. Click Forum Home and a scroll down page will come up.
Scroll down the page and the various help pages and sub forums shall be shown.
Please read the Terms of Use on the very top of the scroll down page - they are our rules.
To save time here's the link
https://metalworkforums.com/f90/t197...terms-tou-read
Many pages also have a sticky at the top.If you post its always a good idea to check the sticky ,if there is one there.
Please post your questions in the appropriate MetalWork forum.
Again, welcome to our forums.
2nd Aug 2021, 10:48 PM #3New Member
- Aug 2021
- 70
- 6
Thanks for the welcome, Grahame. I'm looking forward to participating in some interesting discussions on here.
3rd Aug 2021, 01:53 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
That link didn't seem to work for me unfortunately but I had an older flat bed macson and had the apron off it a few times.
1. Get the leadscrew/feed rod bracket off the tailstock end of the bed. On mine there were some tapered pins that were threaded on the and and you had to righten nuts to back them out.
2. Disengage the half nuts, disconnect the leadscrew and feed rod from the feeds gearbox on the headstock end. The leadscrew is just held in its socket by a tapered pin, the feed rod is held into a feed overload clutch again with a tapered pin I think.
3. Pull leadscrew and feed rod out the RHS of the apron. This should leave the apron hanging in air with nothing running through it
4. Chock the underneath of the apron up with wood blocks. Be careful to support it in a way you can lower it easily. Mine probably weighed 65kg or more.
5. Undo bolts holding apron to carriage
6. Lower apron, done.
For me the thing that happened most often was the overload clutch didn't slip easily enough so if you fed it into its end stop it would twist the push pull lever that changed between sliding feed and surfacing. I had to remake that more than once before I lightened up the preload on the feed clutch.
3rd Aug 2021, 03:28 PM #5Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 455
Welcome to the forum.
3rd Aug 2021, 06:35 PM #6Senior Member
- Feb 2014
- Werribee, Melbourne
- 178
Welcome aboard.
3rd Aug 2021, 11:33 PM #7New Member
- Aug 2021
- 70
- 6
Thanks very much for the comprehensive description, Caskwarrior.
If it's the same problem as you experienced, I might make up a couple of spares of the damaged part/parts. Just in case.
3rd Aug 2021, 11:34 PM #8New Member
- Aug 2021
- 70
- 6
Thanks, Ray-s and old-1955.
