Results 1 to 10 of 10
Thread: Looking for a piston ring
18th Dec 2023, 08:13 AM #1Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,960
I want to replace a one piece, iron oil scraper ring with a multi-piece steel type.
It's for a single cylinder motorbike engine.
Dimensions are to suit cylinder bore size of 87mm, ring groove height 5/32", depth of groove a bit over 5/32".
Are there suggestions for suppliers?
18th Dec 2023, 09:29 AM #2Golden Member
- Dec 2007
- 641
Not sure if JP Pistons in Windsor Gardens, Adelaide is still operating, some years back they made me a set of rings for a Honda S600 Roadster.
Back in the day when I was playing around with bikes multi-segment rings were known as Cord rings, maybe do a search for Cord ring set.
18th Dec 2023, 01:15 PM #3Senior Member
- Apr 2018
- 181
Try HB sales 27 Church st Perth 6000 (08) 93283043
18th Dec 2023, 03:13 PM #4China
- Dec 2005
- South Australia
- 1,692
JP are still in business brings back memories, quite some years ago they were the only company in Australia or the UK who could supply standard size pistons for a Cortina I was rebuilding
18th Dec 2023, 05:57 PM #5Mechanical Butcher
- Oct 2004
- 1,960
Thanks familyguy & China.
I won't deal with JP as they gave me wrong info in the past so I wasted money.
I have some Cord rings that I bought for another bike. They look like a stack of compression rings with rounded edges, that work as a wiper (oil control) ring.
That's not the style I'm looking for now. Do Cord also make rings with top & bottom chromed rails and seperator between them?
18th Dec 2023, 08:13 PM #6Mechanical Butcher
- Oct 2004
- 1,960
Thanks Sparksy,
The landline phone number has been disconnected, now they are using moble number 0411 864 249.
George at HB Sales had a look and could only find a ring that is a different design from what I'm after. It is solid, similar to an iron ring but with a groove behind where a spring resides.
I might still get it if I can't find one with two separate rails and an expander between them.
Jordan
19th Dec 2023, 04:34 PM #7
Rings
Used to be a few specialist firms making piston rings. I found this one with a quick google search.
Products | Phoenix Piston Rings | Clayton North | 03 9544 9169
20th Dec 2023, 11:33 AM #8Senior Member
- Apr 2018
- 181
21st Dec 2023, 09:38 AM #9I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 40
- 1,391
If you're talking about this type:
I've got some here as part of a set that were supplied with a set of pistons made by (from memory, I didn't get them done) this mob in Dandenong: https://specialpistonservices.com/
They mention bikes on their website, so might be able to source the size you want.
21st Dec 2023, 10:43 AM #10Mechanical Butcher
- Oct 2004
- 1,960
Thanks for the tip, J&H.
Yes, that's the 3 piece ring I want.
This firm says they can supply a ring in the required size: https://www.autosurplus.com.au/
I ordered it and a scraper ring for the second groove.
Hopefully my old 4 stroke banger will use less oil than a 2 stroke in future.
How to machine piston rings
By morrisman in forum METALWORK GENERALReplies: 46Last Post: 6th Jul 2017, 09:31 PM -
What could this piston be out of?
By Gestalt in forum METALWORK GENERALReplies: 25Last Post: 28th Feb 2015, 09:55 PM -
Replacement Hydraulic Piston Ring
By simonl in forum METALWORK GENERALReplies: 4Last Post: 21st Oct 2014, 04:27 PM -
Piston Grinder
By Oldneweng in forum METALWORK GENERALReplies: 6Last Post: 17th Dec 2013, 09:01 AM -
What to do with this piston?
By jack620 in forum METALWORK GENERALReplies: 32Last Post: 13th Aug 2013, 10:56 PM
