Results 1 to 2 of 2
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,513
    Default Hilux Burnt Earth Lead
    Brother rang today saying his Hilux was hard to start and there was smoke from under bonnet. There was a burnt earth lead. The one from firewall to block. Went and had a look and could not see any cause for that happening at that time and lead was still sort of ok, with mostly insulation burnt. Started it and he drove to my place so I could investigate more. I figured that the lead may have been drawing excess power to get that hot so did some checking.
    Found the cause. Someone who shall remain nameless had forgotten to reconnect the earth lead from battery to block last time he was working on it. A lot of current was flowing through the other earth lead to inner guard and then through this lead to the block for the starter. Surprised it did not end up more serious as that small cable would have been well and truly working beyond it's capacity. New earth lead for firewall to block and reconnect the battery/block earth and all is good now.
    Nev.
    Apr 2018
    168
    Never mind the starting current trying to find other paths from the starter motor. Through gearbox, exhaust etc.
  1. 2002 Toyota Hilux ute tub into a trailer
    By Garry Edwards in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 15th Jan 2015, 12:11 AM
  2. Steel Tray for Toyota Hilux
    By fransjordan in forum METALWORK GENERAL
    Last Post: 27th Nov 2013, 10:33 AM
  3. earth quake just hit here
    Last Post: 22nd Jun 2012, 12:07 PM
  4. Racks for the Hilux
    By wayno60 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 5th Dec 2008, 12:22 AM
