Results 1 to 3 of 3
Thread: Clear coat.
    Sep 2021
    Adelaide
    73
    117
    Default Clear coat.
    I've clear coated most of the polished aluminium, smaller bits, just have the wheels to finish. Unfortunately, the clear coat dulls the shine quite a bit. Funny stuff to spray on polished aluminium: I had to spray a very light coat first, give it a few minutes then hit it again with a heavier coat so the paint would pool and flatten out. Still a bit of orange peel though, particularly on the triangular engine mount. The clear coat doesn't behave the same over painted surfaces, just polished aluminium, very disappointed in the finish. I may not clear coat the wheels as they'd be hard to get the clear to pool, there's a very fine line between pooling and a run. Float coating seems to just run and build up on the edges. I'm also thinking of painting the side covers black, they just didn't come up to scratch.
    Oct 2004
    Southern Highlands NSW
    1,898
    Looks fine to me.
    Hope they stay that way for a while.
    Sep 2010
    Lebrina
    1,914
    I'm not sure that you will ever match the shine of polished Aluminium with any clear coat straight off the gun. I suspect that further polishing of the clear may be required.
    I also wonder, when looking at the triangular engine mount, if there may not be some polish residue that is reacting with the clear coat.
  1. Final coat.
    By Hoggo1951 in forum AUTO RESTORATION
    Last Post: 12th Jun 2022, 09:29 AM
  2. Soldering Galvanized Steel for Powder Coat
    By TwoHillsStudio in forum METALWORK GENERAL
    Last Post: 12th Mar 2022, 03:28 PM
  3. Replies: 1
    Last Post: 30th Jul 2020, 11:04 PM
  4. Coat suggestions
    By phaser in forum METALWORK GENERAL
    Last Post: 11th Jun 2018, 07:22 PM
  5. Clear coat for polished parts
    Last Post: 10th Feb 2011, 08:57 PM
