Results 1 to 6 of 6
9th May 2022, 01:40 PM #1Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Software for drawing wiring diagrams?
I need to draw several schematics for a RV bus I wired up.
Can anyone recommend a free or open source app? Dirt cheap also considered.
It should be able to draw lines and text, and preferably have a basic library of automotive symbols.
9th May 2022, 05:28 PM #2Golden Member
- Apr 2009
- Kingswood
- 930
nadroj,
I use QElectroTech for ordinary electrical schematics.
The key is make your own library of elements, the standard libraries provided are a dog's breakfast to navigate through.
When you find an element in the standard library that you like, copy to your own library.
Using the package to draw is just a bit 'quirky', but you get accustomed to it.
My experience is on Linux, but the website lists Windows.
Keep well,
John,
10th May 2022, 11:24 AM #3Mechanical Butcher
- Oct 2004
- 1,898
Thanks John,
I had a look at QElectroTech but it seems like too much to learn and modify before I can make use of it.
I'm wondering if it would be sensible to use Inkscape, which is already on my Linux computer?
There's lots of tutorials online for it.
Years ago I designed my house using Photoshop - not really ideal but it's what I had and had the advantage that it could be copied, modified and printed, saving a lot of pencil work.
10th May 2022, 12:45 PM #4Golden Member
- Dec 2007
- 574
Here's an Inkscape circuit I did a few days ago for an amp restoration I'm undertaking - not sure how familiar you are with Inkscape but my suggestion is to make good use of the layers, ie wiring on one layer, relays on another, text on another, fuses on another etc - not only makes it easier to edit, but but you can turn off say all of the main wiring and only have the audio system wiring on display and print just that - makes it easier to follow the audio wiring diagram when the time comes to actually so the work.
10th May 2022, 06:53 PM #5Mechanical Butcher
- Oct 2004
- 1,898
I'm encouraged to find several tutorials on YouTube, for circuit diagrams using Inkscape.
There are also libraries of various symbols, but I haven't found any specific for auto electrics yet.
But as it's a drawing program, that should be easy enough to make my own, even for a lazy bourke like me.
Being a so-called vector type drawing system, I need to get used to this as I've only used raster type before.
I did use layers with these, so I'm already familiar with this concept.
Thanks fellas!
10th May 2022, 10:37 PM #6New Member
- Jan 2015
- Latrobe Valley
- 4
For basic block diagrams - DrawIO is a good one.
Drag and drop and easy linking of blocks.
Can get more detailed for schematics, just takes time.
A simple CAD drawing request
By jhovel in forum GENERAL DISCUSSION / OFF TOPICReplies: 4Last Post: 13th Jul 2017, 11:23 PM -
Need help with a Chuck Drawing
By SurfinNev in forum METALWORK GENERALReplies: 20Last Post: 25th Jul 2012, 07:49 AM -
Trouble attaching a drawing
By neksmerj in forum METALWORK GENERALReplies: 18Last Post: 12th Dec 2010, 07:17 AM -
technical drawing
By tanii51 in forum METALWORK GENERALReplies: 6Last Post: 1st Dec 2009, 06:56 PM -
wiring/technical diagrams on old CIG welders.
By Com_VC in forum WELDINGReplies: 10Last Post: 21st Apr 2008, 09:53 AM
