Results 1 to 1 of 1
Thread: Mk2 hose divider.
26th Apr 2022, 01:56 PM #1Banned
- Sep 2021
- 73
- 117
Mk2 hose divider.
Mk2 divider looks a lot better, although, unlikely to please OCD sufferers, me included! The lower hose connects behind the divider along with the switch, the upper hose connects to the side, but the connections are less noticeable on Mk2.
The unit was mounted in the four jaw to effect the rounded ends. The rounded front was done by chamfering the square edges at 45 degrees, then rounding the four edges on a belt grinder, then smoothed over with a nylon fibre wheel before being polished - very carefully! A rotary table or CNC could have done a better job, but as I don't have either, the belt grinder sufficed. Probably a few other ways of doing it, but I'm happy with the outcome and that's all that matters.
The unit is bored 3.2 mm for the length of the divider, 130mm, so had to be drilled from either end, one end being blanked off by drilling and tapping M6 then blanked off with a threaded plug and copper washer.
Looking for a 1/4 BSP to 5mm stainless hose barb
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 13th Apr 2016, 12:22 AM -
Oxy/lpg hose life
By bob ward in forum WELDINGReplies: 7Last Post: 22nd Mar 2015, 01:36 PM -
A Tasty Morsel But What Is It? A Verniered Divider?
By Anorak Bob in forum METALWORK GENERALReplies: 3Last Post: 23rd Aug 2014, 01:47 PM -
Type R or T Hose?
By rrjtedge in forum WELDINGReplies: 1Last Post: 19th May 2011, 07:02 PM
