Results 1 to 1 of 1
Thread: Clutch slave cylinder
4th Mar 2022, 08:07 PM #1Banned
- Sep 2021
- 73
- 117
I sent off for a hydraulic clutch slave cylinder and some hoses, they arrived today and I was pleasantly surprised. The slave cylinder mounts where the original cable was and pulls on the lever attached to the course thread screw. It was cheap and is pretty darn good quality, just not sure it will work that well as the bore is only around 12_14mm. Tomorrows job.
Some hydraulic hoses also arrived, these were advertised as 'braided' but certainly there is no external braiding. They are quite small in diameter and appear to be made of some sort of plastic with braiding of some sort under the clearish outer surface. The smaller of the two came with three banjos: straight, 28 degrees and 90 degrees. Again, they appear to be quite good quality.
The slave cylinder and hoses were only bought to play with, but if everything works ok, I may look at the hoses for brake lines. I'll be on the lathe again shortly to make a slave cylinder that pushes on the clutch actuating rod, not a fan of the course threaded screw actuator.
Clutch assembly help please.
By Vicval01 in forum SHERATON AREAReplies: 7Last Post: 1st Jun 2020, 11:51 AM -
How to make a dog clutch
By TommyGMachining in forum Members VideosReplies: 0Last Post: 20th Oct 2019, 09:06 PM -
Single revolution clutch- pin clutch or similar unit
By nswnotill in forum METALWORK GENERALReplies: 27Last Post: 20th Dec 2015, 07:22 PM -
Resleeving brake slave cylinder
By .RC. in forum METALWORK GENERALReplies: 36Last Post: 21st Jan 2013, 05:02 PM -
clutch for lathe motor
By YarrD in forum THE HERCUS AREAReplies: 15Last Post: 27th Jan 2011, 05:26 PM
