Results 16 to 30 of 38
12th Feb 2022, 10:07 AM #16
The block is die cast from the look of it.
What date is it?
Really cool looking engine, if you were up here in Sinny I’d luv to have a decko
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
12th Feb 2022, 02:51 PM #17
12th Feb 2022, 03:06 PM #18
Thanks mate Yeah it will be more of a straight line cruiser, i may go with a three wheel trike don't know yet. Other people have made v8 motorcycles with these motors. I have a 76 Honda goldwing rolling frame, may have to stretch it a bit. Lots of R&D to do. https://www.youtube.com/watch?v=WEFJ9kkFGN0
6589947.jpg6589948.jpgta08.jpgta11.jpgta07.jpgGuzzi-Tatra-V8-Glemseck-2019_0-1024x618.jpgGuzzi-Tatra-V8-Glemseck-2019_1-1024x674.jpg
18th Feb 2022, 02:09 PM #19
Cleaning still continues on the cylinder heads and cylinder,as i was cleaning this set of rocker arms one side pop off which should not happen as they are press on and i could see some grinding marks on one side of the rocker arm and this was the side of the block were one of the tappets was broken. Decided to chuck up the longer push rod and it is bent, the short one is OK. So replacement is required, will be a couple more push that will be bent i will find out as i couture with the cleaning of the parts.
19th Feb 2022, 07:19 PM #20Golden Member
- Jun 2005
- Helensburgh
- 618
Malcolm Oastler built a bike with a Simca Vedette V8 in it some time ago which may interest you. He is an internationally recognised race car designer who has worked in both F1 and American open wheelers so he builds stuff properly.
CHRIS
19th Feb 2022, 08:43 PM #21
20th Feb 2022, 07:50 AM #22Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
20th Feb 2022, 09:22 AM #23
Tatra makes some nice trucks https://www.offroadtrucks.com.au/?gc...RoChGsQAvD_BwE
20th Feb 2022, 06:13 PM #24Diamond Member
- N.W.Tasmania
- 1,407
Not having any experience at all with 3D printing, of course I may well be totally wrong, but I would think that it would be quite feasible to make a distributor cap that way. Years ago I had an old magneto refreshed by a chap here in Tasmania who collects and restores old machinery. He had an amazing collection of tractors, all restored and looking in near new condition, as well as I would think, hundreds of chainsaws in similar condition arranged on shelves in a shed that held nothing else, all very impressive.
When he had to make distributor caps or magneto distributors for restorations, he would glue the broken one back together if possible, and bog up any missing bits, and then make a mould before laying the part up in fibreglass. He did an amazing job of it, and from the outside they looked indistinguishable from a brand new cap, colour and even brand on the one I saw, - really smick! It was only when you turned it over and looked at the inside of the cap that you could see the glass matt finish. I don't recall how he did the terminals, but the caps were all fully functional.
I imagine that if you were a dab hand at programs like Fusion 360, printing a cap would be a lot less work than making a mould and then laying it up in glass and fitting all the terminals in just the right spots and in correct alignment.
It's all a moot point here though as the OP is doing away with the distributor altogether, another great project Turbine Builder.
20th Feb 2022, 11:20 PM #25
Thanks Ropetangler All good have purchase distributor and two distributor caps and two sets of brand new inlet valves for a reasonable price. Been in talks with Alec in the UK he is what he said about the rear crank oil seal and some pics of what he done they always leak oil with the rope seal so this will have to be done on my engine block.
OK, lets get rid of that rope seal.
Had to generate out the original diameter. there isn't enough meat there for a standard seal because there is a labyrinth behind it so you have to make do with that & reduce the thickness of the circlips & also reduce the thickness of the oil seal.
Then you have to machine the finger off the crank & shring a new sleeve on & cylindrical grind it. No pictures of that sorry.
Use nitrile cord in the 2 vertical seals instead of asbestos rope.
s-l16dd.jpgs-l16ll.jpg0576e075e6d4.jpg017f6387328c.jpg84035b6e0670.jpgaa6bc906715d.jpgdd10eea8b8d0.jpg
9th Apr 2022, 04:34 PM #26
Got some new parts for the motor, got all the gaskets for the motor, 2x new sets of exhaust vales , 2x new sets of inlet vales, new timing chain, 1 x small timing chain sprocket, 3 x distributor caps and NOS set of cylinders they were selling at a good price so i grab them, 1 x use inlet manifold. Also got a use engine block should be here in May.
!cid_0312EBD3-08CF-49B3-873B-B93C832D1663.jpg!cid_E8AC2710-62B0-47C5-B714-94676512052C.jpg!cid_FE81FFBC-6F55-4AAD-83AF-9DBBD787ED1D.jpgsandblasting cabinet 001.jpg014.jpg
9th Apr 2022, 04:39 PM #27
Got a couple of photos of this bike with a Tatra motor installed, from Czech Republic i think.
custom-bike-cylinder-engine-v-paaren-im-glien-germany-may-black-white-oldtimer-show-mafz-5569887.jpgcustom-bike-cylinder-engine-v-paaren-im-glien-germany-may-oldtimer-show-mafz-55698736.jpg
23rd May 2022, 04:30 PM #28
Parts collecting continues, got a set of new exhaust valves and a set of use con rods, rocker arms, distributors, cabs, coil, cylinder heads.
Tatra parts 001.jpgTatra parts 002.jpgTatra parts 003.jpgTatra parts 012.jpgTatra parts 013.jpg
23rd May 2022, 08:59 PM #29
[QUOTE=Turbine Builder;1996640]Got a couple of photos of this bike with a Tatra motor installed, from Czech Republic i think./QUOTE]
Looks like a Ural frame and gearbox.... You could use a BMW twin more easily here in Oz....like in the Youtube rat rod you showed earlier.Cheers, Joe
23rd May 2022, 11:07 PM #30
[QUOTE=jhovel;1998139]Hi Joe, yeah i was looking at the BMW but i got the goldwing frame for a good price,as for gearbox will get a moto guzzi box and clutch. AH!! so it might be a ural motorcycle Looks like they are still in production https://www.imz-ural.com.au/c-t
Steam engine, Bolton No 7 horizontal mill engine.
By A J in WA in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 15th Nov 2020, 04:26 PM -
Huxtable Hot Air Engine
By Jim Ferrous in forum Members VideosReplies: 0Last Post: 16th Sep 2020, 04:27 PM -
Tatra air cooled V8
By bob ward in forum AUTO RESTORATIONReplies: 6Last Post: 8th Jul 2019, 09:14 AM -
Search engine
By Grahame Collins in forum METALWORK GENERALReplies: 4Last Post: 21st Dec 2012, 06:57 PM -
Stirling engine help
By xXvapourXx in forum METALWORK GENERALReplies: 14Last Post: 9th Jul 2011, 11:35 AM
