Results 31 to 38 of 38
24th May 2022, 04:16 PM #31
Alan Millyard installed an 8 litre V10 into a bike frame and ran over 200 mph (320 kph) so this one should be a doddle in comparison.
https://www.youtube.com/watch?v=ZtRnAI1jHao
24th May 2022, 04:54 PM #32
12th Aug 2022, 07:43 PM #33
Just got a spare engine block this one is the H block, all i know at the moment about the H block is the tappets are different and i think the cam is to Will look into more tomorrow so far looks to be in good shape. LOL it only took about 6 months to get here
IMG_20220812_175511.jpgIMG_20220812_175535.jpgIMG_20220812_175557.jpgIMG_20220812_175650.jpg
14th Aug 2022, 02:33 PM #34
Remove the tappets and cam shaft,they are the same as in the first engine i strip down. My thinking it will look like this one in the photo,anyway the tappets look to be in good shape and so those the cam shaft all good for spares Did a mock up of the block and goldwing frame,will need to stretch the frame a bit but i think it's doable Just purchase Moto Guzzi gearbox housing for mock ups and measurements purposes as well.
Tatra parts 001.jpgTatra parts 003.jpgs-l1600.jpgTatra parts 005.jpgTatra parts 006.jpga39211-1-2.jpg_t_1639524025.jpga39211-5-2.jpg_t_1639524025.jpg
17th Aug 2022, 05:44 PM #35
Started media blasting the heads with walnut shells, not good need high pressure so change over to glass beads and WOW!! cleans up very nicely I found on 3 of the heads so far there is a split,hole on the inlet side there is a shim that is place over that area which may seal it the split hole the hole breaks thru the push rod hole.
Tatra parts 013.jpgTatra parts 014.jpgTatra parts 015.jpgTatra parts 016.jpgTatra parts 008.jpgTatra parts 009.jpg
17th Aug 2022, 07:43 PM #36Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
i don't think those holes really need to be sealed as the rocker area and the pushrod tube are both common to the oily side of the engine. probably a bit of core shift + soviet quality.
17th Aug 2022, 08:05 PM #37
16th Jan 2023, 07:47 PM #38
After about 6 months i finally received my Tatra motor and block with crank,cam shaft, oil pan and timing chain cover plus some other bits. The motor has 50 hours run time on it, this type of motor is use on gen sets and has a bit more higher compression uses a single carburetor and a mechanical speed controller which has been remove.
tatra 100.jpgtatra 099.jpgtatra 098.jpgtatra 097.jpgtatra 096.jpgtatra 095.jpg
Steam engine, Bolton No 7 horizontal mill engine.
By A J in WA in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 15th Nov 2020, 04:26 PM -
Huxtable Hot Air Engine
By Jim Ferrous in forum Members VideosReplies: 0Last Post: 16th Sep 2020, 04:27 PM -
Tatra air cooled V8
By bob ward in forum AUTO RESTORATIONReplies: 6Last Post: 8th Jul 2019, 09:14 AM -
Search engine
By Grahame Collins in forum METALWORK GENERALReplies: 4Last Post: 21st Dec 2012, 06:57 PM -
Stirling engine help
By xXvapourXx in forum METALWORK GENERALReplies: 14Last Post: 9th Jul 2011, 11:35 AM
