Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 80
  1. #16
    Sep 2009
    Sydney
    666
    Full day on BMX today but not really much to show for it. Step 1 was to finish getting all the parts ready for paint, this included lots of time on the bench grinder with a brass wheel, getting the brake mechanism stripped. I suspect they are powder coated but I got them completely stripped.
    The pain was the frame. Whilst the stripper worked it didn’t do enough to get it ready for paint. So plenty of time with a brass wheel on my impact driver plus some sandpaper and I had it down to this:
    I used 80 grit to clean it up, so used some 180 and 240 to try and clean up the sanding marks. I believe the metal flake hides a lot of sins so was going to go ahead with how I have it now.
    Next up I built my spray booth. Last time I did it I tried to make a positive pressure booth but it didn’t really work because my fan wasn’t strong enough, so this time I build the frame and closed it in on all sides but 1.
    Everything else in the shed is covered for overspray protection, but I’ll keep the paint rate low as I only have tiny pieces.
    All hung in preparation for primer. Still need to clean them with wax & grease remover.
    Tomorrow the plan is primer, white for the parts hanging and depending on how that goes, maybe some sanding and/or laying some purple metallic.
  2. #17
    Jun 2007
    Ipswich QLD
    68
    1,996
    Thats some booth ideal tho. Plenty light to see whats going where is needed.
  3. #18
    Dec 2007
    Sydney
    395
    Bit late now but as a kid I wanted to paint my 26”.
    So my dad (who was a fitter and turner ) gave me a broken piece of hacksaw blade with the teeth ground off to scrape the old paint off with.
    It took me forever, but compared to sanding which was endless by hand it was the way to do it.
    H.
    Jimcracks for the rich and/or wealthy. (aka GKB '88)
  4. #19
    Sep 2009
    Sydney
    666
    Turns out I can’t lay the purple without putting clear on top. As I’m still waiting for the metal flake this poses a question. Do I clear now and rub it for the flake or wait till I have the flake?
    A light coat of clear would protect the metallic if I get the flake wrong but my head is thinking I just leave them in primer for now and focus on finishing the white parts instead.
  5. #20
    Jun 2007
    Ipswich QLD
    68
    1,996
    What happened to sealer coat?
    Clear is a finish coat
    You can mix clear in the purple flake 5% should be enough to give greater depth. The still clear over the top.
  6. #21
    Jun 2007
    Ipswich QLD
    68
    1,996
    Quote Originally Posted by clear out View Post
    H.
    Henry thats so long ago it would have been baked enamel lead based at that.
    I didnt know they made Penny Farthings in 26" Painting metal flake
  7. #22
    Sep 2009
    Sydney
    666
    Doing the primer sealer on all parts first. Then will lay down the white on everything other than the frame and forks. That will have them all done.
    The forks and frame I have the option to lay the purple today too if I want, but the spec sheet says I have to clear or lay another coat of purple before clear.
    As I will have the flake in the clear I’d rather not be mixing up clear twice so was thinking I would do the purple, flake (in clear) and clear in 1 go (when the flake shows up).
  8. #23
    Jun 2007
    Ipswich QLD
    68
    1,996
    Why arent you ,mixing the flake in with purple & clear coat? Then do a purple 25% & 75% clear?
  9. #24
    Sep 2009
    Sydney
    666
    Default Painting metal flake
    Because the metallic base coat is not 2k but the clear is. I also don’t have the flake here yet unfortunately, otherwise I’d be laying it all today ideally.
  10. #25
    Jun 2007
    Ipswich QLD
    68
    1,996
    I'd wait till you have it all
  11. #26
    Sep 2009
    Sydney
    666
    Quote Originally Posted by wheelinround View Post
    Ok, great. That was my thinking too.
  12. #27
    Sep 2005
    Bendigo
    60
    419
    A clear coat is required over any metallic automotive finish to protect it, are you saying the instructions say the clear must be applied within a certain period ?
    Some of the painters I have been involved with will lay the color coat then let it dry, sometimes for days / weeks. The coat is then wet sanded to get a dead flat surface before the clear coat is applied.
  13. #28
    Sep 2009
    Sydney
    666
    Yep, that’s what the spec sheet says (bottom bit):
  14. #29
    Sep 2009
    Sydney
    666
    Ok that went well. I haven’t painted much other than a few kitchen doors but I’ve been watching non stop YouTube videos to get ready Painting metal flake
    Laid down my primer sealer, mist coat first, then once I’d finished the last piece it was pretty much time to go around again.
    Second coat was a little heavier and then a third, mainly because I had enough paint in the gun still and didn’t want to pour it away.
    I took the frame and forks out of the “booth” in preparation for painting the white.
    What I learnt:
    I’m pretty comfortable I got my gun setting right. Almost no fan and adjusted my pressure down by feel as I don’t have a pressure regulator on the gun. Went light on the paint flow and I think it worked out well, I got almost no overspray and managed to get 3 primer coats out of 225ml.
    Also I don’t have anywhere near enough light. I meant to grab 2 lights at Bunnings this morning but annoyingly forgot! So for the white I decided to move each piece to the front of the booth each time as I could see what was going on.
    The white paint was interesting. I used the same process of applying a light most coat first, then a heavier second and almost wet third. It worked really well on most parts and I got a nice gloss, but a couple of inclusions and one piece wasn’t quite as shiny as the others which I’m putting down to surface finish as it was stripped. I’m not worried as it’s the inside of the front sprocket.
    I mixed way too much of the white too (150ml) and i ended up pouring a bit of that away too. I definitely only need about 100ml for the frame and forks max, maybe less.
    Full dry time is 16 hours on the white stuff (PPG 625 Polythane) so I’ve left it hanging in the booth until it’s dry.
    I’m planning on sanding and polishing these bits out of the white, do people think that would work?
  15. #30
    Jun 2007
    Ipswich QLD
    68
    1,996
    Neevo do yourself a big favour and block the crank and fork thread areas asap. You'll end up with to much paint in the threads and have trouble putting it together, it will also damage the paint around when trying to thread it together. Berore doing anymore coats make sure threads are easy to put together, yes run the nuts into over the thread then push in paper or rag to protect during all other coats.
  1. Painting machines
    By .RC. in forum METALWORK GENERAL
    Last Post: 17th Sep 2013, 12:33 AM
  2. Painting
    Last Post: 6th Jun 2012, 10:55 AM
  3. Painting the trailer
    By buildspacetrain in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 10th Aug 2010, 07:10 PM
  4. Painting black metal
    By JillB in forum METALWORK GENERAL
    Last Post: 25th May 2009, 01:12 PM
  5. painting metal
    Last Post: 8th Oct 2007, 10:55 PM
