Results 1 to 10 of 10
    Mar 2011
    Taree NSW
    119
    Default Fuel smell in car
    I have a fuel smell within my car which I have been unable to stop - all hoses have been renewed with unleaded compatible rubber, the tank has been pressure tested and there are no visible leaks - when I last checked the sender unit the 'O' ring had grown in length so I replaced it with another - maybe that 'O' ring is also incompatible with petrol so I will check its composition - the tank doesn't appear to be vented - any ideas? The car is a 1969 NSU Ro80
    Jun 2005
    Helensburgh
    618
    Is the smell present before starting the car? There are a myriad of things to check as you are obviously aware of, maybe a wrong float setting, leaking needle & seat might be culprits and it does not take much for the smell to be noticeable. Try searching with a lit match........I'll leave before you do. One thing you might do and only very carefully is to use a few PSI of compressed air to pressurise the whole system but the vents will need blocking off as cars this old did not have sealed fuel systems and the whole system between the pump and the carburrettor only operated at 2 to 3 psi and anything more overcomes the ability of the needle & seat to seal. Have you checked the float to make sure it does not have a leak as well? So many possibilities and not much fun trying to find the reason makes a job like this very hard.
    CHRIS
    Dec 2005
    South Australia
    1,658
    Carburetor cars pretty much always have some lingering fuel smell, in older vehicles it will enter the car through a 101 places worn wind lacing, worn window seals, worn grommets at body perforations
    etc. etc.
    Jun 2005
    Helensburgh
    618
    Quote Originally Posted by China View Post
    etc. etc.
    Not in my experience at all if the system works the way it was designed and has no faults. They are certainly more susceptible to more faults as modern methods have ensured leaks etc are just about a non event. On old cars the system vent on the tank can be a problem if it is damaged or moved.
    CHRIS
    Dec 2005
    South Australia
    1,658
    Ok Fair enough, the car is 50 years old, what I was trying to say is that there are many many many places that fuel or fuel vapours can escape for instance Carburetors are made from zinc type materials and move and
    distort over the years, I suppose what I should have said is it can become very time consuming to find and most people end up just living with it
    Jun 2005
    Helensburgh
    618
    If I couldn't find the leak I would rip the whole lot out and replace everything between the tank and the carby. That would leave just the carby and the tank as the culprits. gee I am glad I gave up working on cars especially old ones, all my tools literally have rust on them due to being no longer used. I often wonder why I even keep them apart from a few metric spanners.
    CHRIS
    Dec 2010
    Syd
    492
    Assuming it's stockish and has a mechanical fuel pump, I'd check if there's residue evident around that. Often found stinky carb cars had a perforated diaphragm - they'd still run fine.
    Jun 2005
    Helensburgh
    618
    Quote Originally Posted by Hunch View Post
    I doubt that is an option to pursue as being a rotary it has no camshaft.
    CHRIS
    Mar 2011
    Taree NSW
    119
    Default fuel smell in car
    Quote Originally Posted by Chris Parks View Post
    Tank is in boot and fuel pump is behind rear seat = there are no visible leaks - 2 mates from local car club brainstormed the problem yesterday and the theory currently is that the tank vents out of the fuel cap which is in a pod on the car side, this pod has a drain to ground which takes care of splashed fuel if one overfills tank - if that drain is split it could allow fuel fumes into car - will check for split and block drain temporarily, also when I had tank pressure tested I found the 'O' ring under the sender unit had grown due to incompatibility with petrol - will replace this 'O' ring with suitable composition material if available - SO, 2 possibilities, will report back when they are eliminated
    Dec 2010
    Syd
    492
    Forgot about this being the devil's device!
    Might find too, even if the rubber hose is good for unleaded, it doesn't necessarily mean it won't smell. There's an E85 car here with alcohol safe hose, still stinks where it's enclosed.
  1. Nothing like the smell of sulphurised cutting oil smoke in the morning
    By bollie7 in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 31st Aug 2018, 09:20 PM
  2. Fuel Tanks
    By Goggomobile in forum AUTO RESTORATION
    Last Post: 7th Jul 2016, 08:06 AM
  3. can you smell smoke?
    By azzrock in forum METALWORK GENERAL
    Last Post: 30th Aug 2012, 02:30 AM
  4. Musty box smell
    Last Post: 4th Jan 2012, 07:31 AM
  5. brazing fuel tank?
    By Mathuranatha in forum WELDING
    Last Post: 26th Apr 2009, 12:14 PM
