Results 1 to 2 of 2
    Jul 2011
    Berowra Waters
    149
    Default Great setup for someone getting going
    https://www.gumtree.com.au/s-ad/mara...rce=ios_social
    this looks excellent and clean. Everything is there too.
    Apr 2008
    269
    Default TU3008 Lathe
    I have one of these, before you buy any lather from H&F or other supplier, have them remove the tail stock from the ways and inspect it for machining. Mine looks to have been ground with an angle grinder.
    I read the hype about Deutsche Engineers overseeing the Chinese Makers building these lathes, sucked in, they must have stepped out on a extended lunch break drinking caffee and eating brotchen when mine was assembled
    The lathe is noisy, more so then the bigger older Herless I have. The comment about H&F not checking the machines before being sent, dont know what other states are doing, know that mine was inspected, was there when they were doing it, removing the shipping oil and replacing it with fresh oil.
    DD
  1. VFD Setup
    By Auskart in forum METALWORK GENERAL
    Last Post: 25th Sep 2016, 12:00 AM
  2. Replies: 25
    Last Post: 23rd Aug 2015, 09:38 AM
  3. Buffing Setup
    By grunto in forum METALWORK GENERAL
    Last Post: 4th Sep 2014, 02:23 PM
  4. Tig setup help asap!
    By BLKWDW in forum WELDING
    Last Post: 2nd Jan 2012, 07:38 AM
  5. 3 Phase setup
    By barkersegg in forum METALWORK GENERAL
    Last Post: 8th Dec 2009, 12:17 PM
