Results 1 to 9 of 9
Thread: Porosity in cast A390
12th Mar 2022, 07:18 AM #1Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
Trying to cast engine pistons in a high Silicon alloy.
Got some ingots of A390, which is meant to be the best alloy for that, but all of the pours have black air pockets near the top, that seem to carry quite a way through the casting (i.e. unable to machine away to get clean metal)
The inside and bottom of the casting are shiny and beautiful.
They are currently being done in a primitive split die, with a side pouring tube that feeds about a third of the way up:
All the dies are well pre-heated.
We are at a loss as to why, have tried a few different top plates (this is the second one, with a smaller vent hole, and a taper inside to try and float any impurities up)
Interestingly, the ingots we bought also have the same "feature":
as does a random dribble that was dropped on out base plate, and I machined the top off.
Here is the last pour from yesterday. Got the alloy extra hot - note the ripples on the surface from the oxy torch:
(haven't dissected the casting yet, but I suspect it will have the same issues)
So, apart from "just sand cast it", does anyone have any suggestions?
12th Mar 2022, 09:10 AM #2Intermediate Member
- Mar 2006
- Waikerie SA
- 39
I don't preach to be an expert but try bubbling argon through your metal before pouring. Just a suggestion! Oh the thrills of casting in the backyard!
12th Mar 2022, 11:05 AM #3Diamond Member
- Aug 2019
- 56
- 1,183
Thanks Vin. First time I have heard of that.
A few web searches say it de-gasses the alloy, reducing hydrogen.
I assume that is bubbled through the ladle?
(because bubbling through the mould/die would be a challenge
in the 10—20 seconds it takes for the metal to solidify!!!
I only have welding gas handy (Ar/C02/O),
but I'll look for an Argon cylinder and try to build a small lance.
12th Mar 2022, 11:51 AM #4Intermediate Member
- Mar 2006
- Waikerie SA
- 39
Yes, bubble the argon in the ladle just before pouring. Also if possible have far more metal in your ladle than you need if pouring small casts. Once again no expert, just a novice!
12th Mar 2022, 12:02 PM #5
Hi Nigel,
First of all a disclaimer in that I have never had anything to do with casting , cast iron.
I have however had much to do with welding it.
By welding, I mean with a water cooled oxy acetylene welding nozzle after the weldment was preheated to a suitable welding temperature with a 50mm gas line.
To assist with the purification of the molten (cast iron) metal, we used a flux.
The flux was borax ,potash and salt.
The flux,purifies molten metal and floats the impurities out and up and they are removed as a crust from the cast iron when cooled.
Porosities and voids were released and also floated out.
1 cup of borax. …
Pour 1 cup of potash into a measuring cup. …
Measure 1/2 cup of table salt. …
Mix the three ingredients together until they are fully combined.
Pour the flux mixture into a lidded jar. …
Use the flux dry. …
Modify amounts used in this recipe to suit your needs.
It needs to be applied and stirred through the molten iron.
Do you think it is worth a try?
12th Mar 2022, 06:04 PM #6Intermediate Member
- Mar 2006
- Waikerie SA
- 39
Grahame is probably on the money, I add borax to both aluminum and bronze melts, I also use it when I melt silver making jewellery. once the melt is ready I scrape the dross add a small handfull of borax, stir and skim the last bit of dross before pouring. Borax can be very harsh on crucibles so use sparingly.
Just in case you are not aware borax can be bought at woolworths!
12th Mar 2022, 07:00 PM #7Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
I think you need a taller sprue to put more head pressure on the molten metal to stop the porosity forming.
12th Mar 2022, 09:43 PM #8China
- Dec 2005
- South Australia
- 1,656
Many health food or save the planet type shops sell Borax in bulk much cheaper than supermarkets
17th Mar 2022, 09:40 AM #9Diamond Member
- Aug 2019
- 56
- 1,183
Haven't tried any more pours yet, but found someone that used to pour this material for racing cart engines.
1) They started the day with a 20kg melt in a furnace, and used that material all day.
2) They added Copper Phosphorous to the melt, to modify and "evenly distribute the silicon" thru the melt. That was after trying various tablet/powder products. I am still researching this:
http://www.milward.com/pdf/8-P-CuS.pdf
my fear is that too much would affect the strength of the alloy.
3) They also bubble Nitrogen through, with a graphite lance for 20 minutes
4) They advised a hotter die — approx 400°C — to help the casting cool more evenly and draw from the sprue. Advocated coatings on the sprue and die; ceramic from the Foseco company.
Not sure it is necessary for these temporary pistons, but the final spin casting die deserves coating.
5) Like snapatap, they also advised a much larger sprue.
We might do this with a second sprue on top.
porosity
By vin in forum THE FOUNDRYReplies: 6Last Post: 23rd Oct 2023, 09:35 PM -
WTB-Cast Small Cast Iron Lapping Plate
By Betnorm in forum WANTED TO BUYReplies: 4Last Post: 19th Nov 2019, 01:01 PM -
Cast Iron
By Auskart in forum METALWORK GENERALReplies: 9Last Post: 28th Jul 2017, 06:08 PM -
Gassless mig / Porosity
By BigPete1 in forum WELDINGReplies: 2Last Post: 10th Feb 2013, 11:47 PM -
Cast iron VS Cast steel lathe compound slide
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 23rd Dec 2012, 11:40 PM
