Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Mar 2006
    Waikerie SA
    39
    Default They are getting big
    It won't be long and the next two will be poured. By the time the outer mantle is done they are going to be huge compared to any I have done.bigbells.jpg
    Dec 2005
    South Australia
    1,656
    You won't be throwing that on the shoulder to move it about, will be good to see it when it comes out of the sand.
    Mar 2006
    Waikerie SA
    39
    Wax work done, tomorrow I paint first layer on!
    Mar 2006
    Waikerie SA
    39
    Three base coats today!
    Feb 2009
    Adelaide - outer south
    67
    18
    Looking good Vin.
    I have no experience with it but that looks like a large casting for the investment process.
    Have you posted anything on the patterns and making the wax models? I'm interested in seeing the full process if you have time to show it.
    Cheers, Bob the labrat
    Measure once and.... the phone rings!
    Mar 2006
    Waikerie SA
    39
    Quote Originally Posted by labr@ View Post
    Looking good Vin.
    The process goes like this, design the bell and make a sweep for the inner core and outer final shape. first use the inner sweep and make a loam mould. Once the core/inner is dry coat it with graphite, them with a weaker loam mix apply the false bell using the outer sweep. Allow that to dry and then apply wax using the same sweep. then you add your wax art work and give it several coats of fire clay before applying a thick loam mud over the clay. Allow a time for it to all dry out about 1week in summer. then you fire the whole mould in a wood fire, this totally dries it and melts out the wax. Once firing is done the mould mantel/outer will separate, you then knock the false bell off, replace the mantel, bury in the ground and pour your metal. Simple
    Mar 2006
    Waikerie SA
    39
    OMG they are big! now I wait for 7-10 days before burning in a wood fire. The second pic you can see the wax riser with the dam in front.
    Mar 2006
    Waikerie SA
    39
    Default Poured last Sunday
    I poured these two bell last Sunday, all went well, new furnace worked good, the jib and ladle carrier also worked good. bells finished weight is 48kgs each, they have cleaned up very well and I have today finished tuning them. I will post some pictured tomorrow.
    Dec 2005
    South Australia
    1,656
    Looks like a family operation will be good to see the progress
    Mar 2006
    Waikerie SA
    39
    A few pictures of replacing the mould mantle after removing the false bell, And the final bells.
    And I only have one bell to go and I start building the carillon frame.
    aaaareadyforfire.jpgaaaaaareplacingmantle.jpgaaaathumbsbell.jpgaaaaafruitbowelbell.jpgaaaaalayout.jpg
    Dec 2005
    South Australia
    1,656
    I have become addicted to this thread.
    Mar 2009
    54
    825
    Those bells look fantastic, great work vin.
    These films show the whole process from beginning to end and just how much work is involved. The voiceover is in German but you can see everything that’s going on.
    https://m.youtube.com/watch?v=gZq4BY...index=30&t=13s
    https://m.youtube.com/watch?v=uS1vUO...index=31&t=46s
    There’s a few channels with similar content to this that I’ve been watching for a long time. They show a lot of old craft clips from a wide range of fields. Unfortunately I don’t understand a lot of German but that’s never been a problem.
    Greg.
    Nov 2004
    Bungama SA
    52
    960
    Nice work Vin, cant wait to see the final product
    I hope everyone here has subscribed to Vin's YT channel
    Mar 2006
    Waikerie SA
    39
    Sorry double post!
  15. #15
    Mar 2006
    Waikerie SA
    39
    Default The last and biggest
    Today I poured the last and biggest bell for the carillon, I was a naughty boy because I felt I went beyond safe level with the A120 crucible making sure I never ran short on metal. I had 122kg of bell metal in the ladle, it turned out I had maybe 10kgs over. I will do some weighing later.
