Results 1 to 4 of 4
    Oct 2016
    408
    Default Lost Foam Casting
    Found this video on Lost Foam Casting, very interesting video on lost foam finned engine cylinder casting. He is using pink insulation foam board, we can get Saviro XPS Blue Board same foam here in AUS just different color.
    https://www.youtube.com/watch?v=WhWy...0I_eOQ&index=3
    Jan 2016
    Wodonga Vic
    37
    578
    You must get the same youtube recommendations as me, I watched this just last night
    Oct 2011
    Norwood-ish, Adelaide
    57
    6,212
    Check with whoever is doing your castings first. I used to deal with a foundry who would not do lost foam as the fumes released from the burnt foam were very smelly and likely toxic.
    Dec 2007
    Sydney
    308
    I did a bit of this at Wollongong TAFE about 25 years ago when they were running Foundry down there.
    It was for broken stop brackets for Wadkin panel saws, quite small items.
    Being a pretty basic shape it was easier than a real pattern and conventional moulding in green sand.
    H.
    Jimcracks for the rich and/or wealthy. (aka GKB '88)
  1. Casting a gear using lost wax
    By KBs PensNmore in forum THE FOUNDRY
    Last Post: 13th Apr 2020, 10:14 AM
  2. Lost Wax vs. Clay Casting
    By RoadRock in forum THE FOUNDRY
    Last Post: 20th Jan 2020, 10:55 AM
  3. Melting brass for lost wax casting
    By inlay chris in forum THE FOUNDRY
    Last Post: 17th Jun 2016, 09:06 PM
  4. Where to get foam?
    Last Post: 17th Jul 2013, 10:04 PM
  5. Sophisticated cutting device for lost foam castings
    Last Post: 22nd Apr 2012, 09:56 PM
