Results 1 to 3 of 3
11th Aug 2020, 07:15 AM #1New Member
- Aug 2020
- Greater London
- 1
First time casting aluminium, is my sand too wet?
Hi all,
I bought some greensand from Artisan Foundry but I can't seem to create a mould. I use talcum powder to help the two halves separate but it never comes apart cleanly like I've seen in demonstrations and any attempt to remove the part causes the sand to crumble.
When I do the squeeze test it it tends to hold it's shape but it doesn't snap cleanly. Is my sand too wet? Or dry? Or some unholy mixture of the two?
Any other advice you can give to a novice caster would be gratefully received as well.
11th Aug 2020, 08:13 AM #2Philomath in training
- 6,542
Welcome to the forum.
One thing with green sand casting is that the sand has to be rammed in really hard. I mean really hard. It may be that it is crumbling because it has not been packed in enough.
11th Aug 2020, 11:31 AM #3Senior Member
- Perth, Western Australia
- 67
- 362
I agree with Michael G, under ramming is a problem a lot of people have when using green sand.
I have seen experienced moulders have trouble with greensand after coming across from CO2 or Furan sands.
Practice more with different ramming pressures and don`t forget to add some gas vent holes.
Tony
Sand casting
By China in forum THE FOUNDRYReplies: 9Last Post: 11th Jan 2020, 12:37 AM -
First time aluminium casting
By jhovel in forum THE FOUNDRYReplies: 10Last Post: 26th Apr 2016, 07:22 PM -
Regenerating oil bound casting sand
By MuellerNick in forum THE FOUNDRYReplies: 11Last Post: 20th Jan 2013, 09:24 PM -
Vacuum assisted casting in core-sand moulds.
By MuellerNick in forum THE FOUNDRYReplies: 22Last Post: 30th Oct 2012, 03:09 PM -
Casting Tools Part 4 - Sand Casting Tools
By RayG in forum THE FOUNDRYReplies: 8Last Post: 9th Dec 2011, 12:03 PM
