Results 1 to 3 of 3
    Mar 2012
    South Australia
    33
    Default Recipe for ceramic cement
    Does anyone have a recipe for a ceramic cement for lining a small kiln for melting aluminium and or brass?
    Thanks in advance
    Apr 2007
    Adelaide Hills
    9
    Quote Originally Posted by alfclp View Post
    Thanks in advance
    Start with https://www.pugmill.com.au/adelaide-ceramic-specialist
    eg. https://www.pugmill.com.au/shop/air%...tail/offset/0?
    There may be cheaper sources, so also search for other pottery suppliers.
    Neil
    Time for a new signature line... just waiting on inspiration
    Sep 2007
    Wentworth Falls NSW 2782
    77
    134
    It should be possible to buy a bag of fireclay but if you want to just mix your own, a 1:1 mix of Plaster of Paris and sand can be used.
    Not sure how long it would last though.
    This is a You Tube of a guy making a small forge but could just as easily be used as a furnace
    https://www.youtube.com/watch?v=Po9EKcOj1uc
    Many of his videos are worth watching.
    Hope this helps,
    Findlay
  1. Drill Press Table Refurbishment ( Or A Recipe For Disaster? )
    Last Post: 30th Jul 2019, 04:50 PM
  2. Recipe for homemade Way Oil
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 6th Jun 2019, 10:43 AM
  3. Ceramic fiber rigidizer, where to buy?
    By Com_VC in forum THE FOUNDRY
    Last Post: 7th Sep 2016, 10:57 PM
  4. re ceramic blanket
    By texx in forum THE FOUNDRY
    Last Post: 5th Sep 2013, 10:47 PM
  5. Calcium Aluminate Cement
    By Stustoys in forum THE FOUNDRY
    Last Post: 18th Jul 2013, 08:03 PM
