Results 1 to 15 of 15
Thread: casting a brass nut
25th May 2019, 10:08 AM #1Senior Member
- Brisbane
- 143
casting a brass nut
Hi all .. Had this in the general section.. some may already have seen it..I need to reproduce this nut for a vintage vice I am working on.. thread diameter is 7/8" or 22.2 mm.. pitch is just over 4 turns to the inch..
because of the mystery number of turns, and as it is brass, would it be possible to cast a new nut around the screw ???
25th May 2019, 10:57 AM #2Most Valued Member
If you were to cast the nut around the bar, you would possibly have a dickens of a job getting it off, as when metal cools it shrinks, causing it to tighten on the shaft.
The best way would be to make a sand plug of the nut. The hardest part would be making allowance for shrinkage, as normally the threads are machined afterwards.
Would you be looking at getting it cast commercially? If so, contact them or a patternmaker, as they would know the shrinkage rate of brass.
Hope this helps,
25th May 2019, 12:46 PM #3Philomath in training
As Kryn suggests, casting the nut around the screw would not be easy. Apart from getting it off (casting hot metal onto a 'cold' screw - natural thermal shrink fit), you would have to choose a length of thread to cast onto that was the most unworn with no surface defects for the hot metal to grab onto. Sealing off the surrounding thread so the liquid metal did not sneak down there is another thing, and you would also be hoping that the metal was fluid enough that it would accurately fill the space between the threads. Not impossible, but not easy either.
From experience I've found that foundry casting is not cheap either. No fault of theirs, but things cost. As an example, I looked at getting a CI casting done recently. I would spend several days making a pattern, they would take some weeks to get to it then charge me a few hundred dollars for the privilege. I bought a billet of CI that I could machine the part out for around $60.
Machining a nut like that from solid is not difficult. I'm doing a couple this weekend (I hope), and I did an ACME bolt/ nut combo last weekend.
I would suggest cutting the thread then rough out the blank on a lathe. Finish with a bit of filing and the chances are no one will ever notice that it is not the original.
25th May 2019, 02:45 PM #4Most Valued Member
To add to what Michael mentioned, if you want to be a real stickler for authenticity, when you've finished machining it, go crazy with a prick punch on just keep tapping it to give that cast look.
25th May 2019, 03:00 PM #5China
- Dec 2005
- South Australia
- 1,657
Needle gun it is much quicker
25th May 2019, 05:54 PM #6Most Valued Member
True, but not everyone is into tattoos, plus not everyone has one for metal either.
25th May 2019, 09:03 PM #7Senior Member
- Oct 2015
- melbourne
- 473
I think the issue here is the thread is not standard, at least it doesn't seem to be.
Know anyone with a cnc lathe or at least electronic lead screw?
Russ
25th May 2019, 10:19 PM #8Philomath in training
Doesn't matter. On my lathe, with a combination of change wheels and the box on my lathe, just about any thread is possible. Some others would have lathes of similar abilities. If your lathe only has a QC gearbox you may be in trouble if the pitch needed is not native to the lathe but other than that, cutting a nut is not much more difficult than cutting an external thread.
CNC or ELS makes it quicker but is not a deal breaker for reproducing a less common thread.
This is a nearly completed 1", 4mm pitch LH nut being cut on a lathe with an imperial leadscrew. I could swap some cogs and cut 15.237 tpi just as easily.
MichaelLast edited by Michael G; 25th May 2019 at 10:29 PM. Reason: Added picture
26th May 2019, 01:14 AM #9Golden Member
- Dec 2011
- 505
There is some stuff online for lathe attachments to adjust the pitch of the thread being cut, but I never got around to making one, despite having a need for cutting odd threads on occasion.
From the archives:
jacquesmaurel.com/machining
www.model-engineer.co.uk/forums/postings.asp?th=84148&p=1
www.youtube.com/watch?v=3wULa5aTPd0
www.mccrone.com/mm/an-adjustable-threading-feed-attachment-for-a-lathe-without-metric-threading-capability/
Ted McDuffie's 'Variable Lead Threading Attachment' | Model Engineer
Apparently the geometry of the setup gives quite consistent thread pitch, provided that the screw being cut is not too long.
Bill
26th May 2019, 02:00 PM #10Most Valued Member
- 2,666
Not a direct answer to the original question, but I recall a while back reading an article about forming one of the engineering plastics(name escapes me ATM) around a leadscrew to repair a flogged nut.
EDIT: It was Acetal and the article was on homeshopmachinest forum.
Might be an option if you're just looking to return the lathe to serviceability rather than an exact restoration.
26th May 2019, 02:23 PM #11Senior Member
- Oct 2015
- melbourne
- 473
This is for a vise, no idea if plastic would be suitable. Love to know though!
Russ
26th May 2019, 09:11 PM #12Diamond Member
- N.W.Tasmania
- 1,407
I'm not sure either, but I can tell you that they make the point sheaves on some cranes out of plastic, (my guess would be Acetal/Delrin) and the one I have seen was on an 80 tonne crane, and the sheaves would have been about 600 mm in diameter from memory. Of course on your vice, the loading may be much higher than it is on the crane (in terms of PSI say) because although the crane load was much greater than you would get on the vise, there would have been many more square inches to support it. Again a WAG, but the shaft through the sheave was probably around 70 mm in diameter.
5th Jun 2019, 02:15 PM #13Senior Member
- Brisbane
- 143
Thanks guys.. I may have to cast a nut blank and machine it to suit a newly made screw of standard pitch.. either way i need a solid casting made of the nut..
Is anyone interested ?
Ken.
5th Jun 2019, 06:07 PM #14Most Valued Member
- Jul 2016
- 35
- 1,522
For a onesie you'll be better off just machining one from bar stock I would think. Pretty hard to lay eyes on a vice nut so noone will know.
27th Sep 2019, 01:45 PM #15Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
If you haven't repaired it already perhaps this different Solution will work.
Run a bit of soft solder into the nut, and sharpen the end of your threaded "bolt" as shown on the Practical Machinist website here: https://www.practicalmachinist.com/v...g-taps-187694/
If the expected service is arduous, use silver brazing rod (silver solder) instead.
In both cases a good cleaning would be required before you start.
Regards,
Alan.
Brass Casting, Poor Surface Finish
By NedsHead in forum THE FOUNDRYReplies: 1Last Post: 30th Jul 2018, 12:40 PM -
Melting brass for lost wax casting
By inlay chris in forum THE FOUNDRYReplies: 4Last Post: 17th Jun 2016, 09:06 PM -
Anyone have any experience casting brass?
By Jim Ferrous in forum METALWORK GENERALReplies: 7Last Post: 27th Sep 2013, 02:32 PM -
Casting about for cast iron casting ideas
By Graziano in forum THE FOUNDRYReplies: 49Last Post: 1st Apr 2012, 12:05 PM -
Casting a brass nut.
By Skew ChiDAMN!! in forum METALWORK GENERALReplies: 6Last Post: 21st Nov 2011, 01:04 PM
