Results 16 to 30 of 44
  1. #16
    7,188
    Hi Bob,
    Its not a block, its a blanket.... but its folded not rolled. make sense? I think not. I'll take a picture. Takes up less space I guess.
    Can you tell me more about the rigidizer you used in your furnace? If I stay with the blanket I assume I'll need to use that also?
    Ah ha, that folded blanket stuff is commonly used here in WA for pizza ovens. I see packs of it for sale occasionally on gumtree by folks who want to sell their excess after making their ovens.
    If any of the blanket is exposed it will slowly fray and fibres will get into the exhaust fumes and go all over the place.
    My understanding is the rigidizer doesn't completely cure this problem but greatly reduces it.
    Are you doing this inside a shed? If so, good ventilation is needed, not just for the remaining fibres but also exhaust gases.
    The rigidizer came in 1L containers and I managed to do my small forge with ~300 mL.
    I bought 2L and it cost $65 but it should do me for many relinings of the furnace.
    Most rigidizers are a suspension of colloidal silica and caustic plus a few other bits and pieces.
    I think the higher temp versions also contain zirconia.
    Here's a typical MSDS
    http://www.morganthermalceramics.com...merica/205.pdf
  2. #17
    Dec 2007
    1,628
    Quote Originally Posted by Toggy View Post
    Trouble is the the trip would be worth more than buying new firebrick.
    Stu, where are you located? Mulgrave is about 40min for me and Dandy about an hour. I could maybe go investigate for you if you need.
  3. #18
    Jun 2004
    Kyabram. Vic
    632
    Stuart,
    Those heavy firebicks are heat retainers and used as face bricks for fireplace and pizza/bread ovens. They soak the heat then slowly emit it. The lightweights are reflective and used in kilns/furnaces.
    I have the lightweights; not sure if they are 1300c or 1700c.
    R & F had carbide and graphite crucibles. IIRC the graphite are the higher temp, but more fragile.
    There were several old gentlemen and I mean that in every sense. When I explained that I intended to make a furnace they almost fell over themselves to help with any question and made numerous suggestions.
    Things were quiet; so maybe I was a fresh new body to talk to.
    If and when I get on track with the project I will certainly deal with them again.
    Ken
  4. #19
    Jul 2010
    9,088
    Hi DSEL74,
    I'm SE Melb so I am likely just a little closer than you, but thanks for the offer.
    Hi Ken,
    R & F? or R & C..
    I was thinking heavy bricks would put up with more "issues" from flames and oil etc?
    Might try and get myself down there Saturday morning. Though I have a couple of other things to pick up.
  5. #20
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hey Stuart,
    Only just found this thread... anything we can help with let me know..
    I knew you'd find an excuse to wear that helmet...
  6. #21
    Jul 2010
    9,088
    Hi Ray,
    Thanks for that. I thought I was a closer to being ready to start putting things together than I am is seems lol
    Though in my defence I am skipping Alum. I've got a gas reg on the way. The plan ATM is to wait until I get a crucible so I know how big things need to be. I'm thinking something that will hold 10kgs of cast iron. To much?
    One of the many things I havent got on the go is titiaium wire.
    6 yards of 20G long enough and thick enough?
    Titanium Color Wire Beadsmith 20 Gauge 6yd 41809 Round | eBay
    There just arent enough fancy dress parties these days
  7. #22
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    Titanium wire? to tie insulation is place? or am i way off.......
  8. #23
    Jul 2010
    9,088
    Hi Ewan,
    Yes, in the lid. I figure it it works for Ray and Josh It will do for me also.
  9. #24
    Oct 2012
    Australia
    621
    Hi Ray,
    On the subject of size, one of the things I wish we could do is to melt a full sized Alum ingot, rather than having to cut it up first.
    -Josh
  10. #25
    Jul 2010
    9,088
    Hi Josh,
    Just how much does a full sized Alum ingot weigh?
  11. #26
    Oct 2012
    Australia
    621
    Hi Josh,
    5.5Kg
  12. #27
    Dec 2007
    1,628
    I don't know if this will assist you in spec'ing your furnace or not.
    Metals - Melting Temperatures
    Melting temperature of some common metals and alloys
    Melting points of some metals and alloys are indicated in the table below:
    Metal Melting Point
    (oC) (oF)
    Admiralty Brass 900 - 940 1650 - 1720
    Aluminum 660 1220
    Aluminum Alloy 463 - 671 865 - 1240
    Aluminum Bronze 600 - 655 1190 - 1215
    Antimony 630 1170
    Babbitt 249 480
    Beryllium 1285 2345
    Beryllium Copper 865 - 955 1587 - 1750
    Bismuth 271.4 520.5
    Brass, Red 1000 1832
    Brass, Yellow 930 1710
    Cadmium 321 610
    Cast Iron, gray 1175 - 1290 2150 - 2360
    Chromium 1860 3380
    Cobalt 1495 2723
    Copper 1084 1983
    Cupronickel 1170 - 1240 2140 - 2260
    Gold, 24K Pure 1063 1945
    Hastelloy C 1320 - 1350 2410 - 2460
    Inconel 1390 - 1425 2540 - 2600
    Incoloy 1390 - 1425 2540 - 2600
    Iridium 2450 4440
    Iron, Wrought 1482 - 1593 2700 - 2900
    Iron, Gray Cast 1127 - 1204 2060 - 2200
    Iron, Ductile 1149 2100
    Lead 327.5 621
    Magnesium 650 1200
    Magnesium Alloy 349 - 649 660 - 1200
    Manganese 1244 2271
    Manganese bronze 865 - 890 1590 - 1630
    Mercury -38.86 -37.95
    Molybdenum 2620 4750
    Monel 1300 - 1350 2370 - 2460
    Nickel 1453 2647
    Niobium (Columbium) 2470 4473
    Osmium 3025 5477
    Palladium 1555 2831
    Phosphorus 44 111
    Platinum 1770 3220
    Plutonium 640 1180
    Potassium 63.3 146
    Red Brass 990 - 1025 1810 - 1880
    Rhenium 3186 5767
    Rhodium 1965 3569
    Ruthenium 2482 4500
    Selenium 217 423
    Silicon 1411 2572
    Silver, Coin 879 1615
    Silver, Pure 961 1761
    Silver, Sterling 893 1640
    Sodium 97.83 208
    Steel, Carbon 1425 - 1540 2600 - 2800
    Steel, Stainless 1510 2750
    Tantalum 2980 5400
    Thorium 1750 3180
    Tin 232 449.4
    Titanium 1670 3040
    Tungsten 3400 6150
    Uranium 1132 2070
    Vanadium 1900 3450
    Yellow Brass 905 - 932 1660 - 1710
    Zinc 419.5 787
    Zirconium 1854 3369
    • T(oC) = 5/9[T(oF) - 32]
    What are you guys paying for you ingots, Aluminium, Brass, Nickel??
  13. #28
    Oct 2012
    Australia
    621
    Quote Originally Posted by DSEL74 View Post
    Depends on the alloy.
    But as a guide low grade Aluminium $2-3 kg(ingot), Brass/Aluminium Bronze(scrap) $5 kg, Silicon Bronze $15-$20kg(ingot)
  14. #29
    Jul 2010
    9,088
    5.5kgs, thats big enough for about 17kgs iron
    If my maths is right that should be doable.
    My Reg turned up today, only just fits on the bottle, misses the guard(?) my a couple of mm's. Got to be lucky sometimes.
    1290C sounds much nicer, though I assume it needs to be hotting thatn that to pour?
    $2-3 kg! my scrappy charges $6.6 kg for his scrap.
  15. #30
    Oct 2012
    Australia
    621
    Specialty scrap dealer, the sell the RMI ingots I'll remember the name later, I had put a post up about them some time ago.
  1. Small Furnace
    By foccacia in forum THE FOUNDRY
    Last Post: 31st May 2011, 11:24 PM
  2. Small furnace
    By Woodwould in forum METALWORK GENERAL
    Last Post: 12th Jul 2010, 02:53 PM
