Results 16 to 20 of 20
14th Aug 2014, 11:42 AM #16
How have you gone with this?
I am casting some polyurethane rubber at the moment, it is suitable for everything from mold making to floor mats, depending on the hardness.
15th Aug 2014, 10:24 PM #17Golden Member
- Aug 2012
- Australia
- 645
Ew, I ended up getting a bit further than the thread detailed. I poured molds, mixed wax and plastic, cast wax and did a bunch of fettling. I ended up getting stopped dead in my tracks due to three reasons. The first being that the Smooth On "OOmOO" was rediculiously expensive ($50 per liter). If I recall correctly, I needed 8 liters to do the mold pictured below. That was just to make a mold to copy the original. I made this mold as a 3 piece mold. Somewhat impressive, and fortunately it came out usable. The next issue that I had after taking a serious whack to the back pocket, was that the wax was developing porosity/air bubbles/voids when I was casting it. Sometimes parts of the mold would have air bubbles removing important features. I ended up shaking it, drilling holes, changing the wax/plastic composition and I could not nail it. I think I needed to do vacuum casting. So stuff started getting complicated and I hardly wanted to fork out another $400...
The third and final reason was that I got very lucky (rare!) and happened upon a supercharger from one of these.. Which meant that the mount needed further modifications. In the end I decided to stop stuffing around and get on with my CNC. As it stands today I am one piece (rather trivial bit) away from having all the mounts done for my RF45 CNC. All the hard work is done, ballscrews are purchased, power supply and NEMA34 Servos are here from the US, and the mounts all bar one piece of AL are done. The CNC will be used to cut the template. Possibly out of wax...
IMG_4964.jpg IMG_4966.jpg mould_section.jpg IMG_4969.jpg IMG_2161.jpg IMG_5025.jpg
15th Aug 2014, 11:01 PM #18
The high grade polyurethane cold castable i am using is about $26+gst a kilo. There is a lower grade that is cheaper. The killer for me is the bonding agent, it is over $100 a liter.
15th Aug 2014, 11:30 PM #19Golden Member
- Aug 2012
- Australia
- 645
The only alternative I know is buying direct from China. I made some inquiries and It was really cheap. Unfortunately the volumes required would only work if there was a group that needed it. It really surprised me how much I needed to do the mount mold. I thought I could do it with 4 liters, but turned out that I needed 8. It was really good stuff to work with though. For small parts it would be pretty darn good. Especially plastic parts that can be poured straight in. I can see how it is really useful for plastic trim parts in cars etc. The result with wax on my large part was hit and miss due to the fact it kept developing air bubbles. It did not matter if I relieved the section with a hole, just migrated the problem elsewhere. I tried different pouring positions in the mold, high, low etc. Different wax temperatures. Different wax/plastic mixes. No matter what I tried I could not get it consistent. I reckon the way is to do it under vacuum.
How much bonding agent do you need per kilo of PU?
15th Aug 2014, 11:59 PM #201915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
want to be a machinist for a job
By xXvapourXx in forum METALWORK GENERALReplies: 28Last Post: 27th Aug 2011, 07:29 PM -
is the sand from a sand blaster carcinogenic???
By new_guy90 in forum METALWORK GENERALReplies: 12Last Post: 24th Nov 2010, 10:09 PM -
Souce of moulding sand?
By graemet in forum METALWORK GENERALReplies: 9Last Post: 22nd Mar 2010, 03:33 PM
