Results 16 to 30 of 56
Thread: Melbourne Foundry Suppliers
28th Sep 2010, 08:19 PM #16Golden Member
- Mar 2010
- Nth Qld
- 687
28th Sep 2010, 09:15 PM #17I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
28th Sep 2010, 10:13 PM #18
Bentonite is "drillers clay" used to make seal between the bore hole and the bore casing ,thats one of its common uses .
If you know any drillers they may be able to tell you where to get it.
Kev."Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
28th Sep 2010, 10:30 PM #19
There's always a 'Health Food' shop that'll sell you bentonite clay (it's a natural detox mineral, doncha' know) - only $20 for 500 grams. At that price, the cat sure does have a spoiled bum!
29th Sep 2010, 07:35 PM #20
Hi Gary,
I wouldn't bother with kitty litter or animal feed supplements, it's not suitable for making green sand unless you grind it, and even then i'm not sure it will be any good.
I bought some stockfeed bentonite, and ended up giving it to the rellies to use for kitty litter, it's much cheaper than the supermarket kitty litter..
If you only plan on doing a few castings every so often then I would recommend you get some petrobond, it's expensive, but worth every penny in terms of quality of casting and it's mostly re-usable.
To make your own green sand, efficiently really needs a muller, so the two paths to get started in casting are as follows...
1. Buy some petrobond and start casting..
or
2. Get FOUNDRY grade bentonite, some good sand, build a muller, learn how to make good quality green sand.... and so on.....
Of course, if you are going to be casting a lot, like a production foundry, then the economics of green sand will win hands down.
29th Sep 2010, 08:17 PM #21Golden Member
- Mar 2010
- Nth Qld
- 687
What are the economics of green sand?, I was under the impression that resin bonded sand worked out better and thats why foundries use it in preference to green sand?. Sure with resin it's easier to throw away the used sand than reuse but because there's no requirement for frames like green sand, so it's easier to make many as many moulds as you have the sand for. The moulds are mechanically strong and handle easy as they don't break with a knock.
I've had this discussion with the professional foundry guy I learn from, he said he wouldn't go back to green sand if you paid him.
29th Sep 2010, 08:48 PM #22
5 bucks per kilo for petrobond, versus 75 cents per kilo.
Edit: That's not really the whole story, resin bonded sand is yet another step up in equipment requirements, not even sure it's really appropriate for a home foundry unless (as I keep saying) you are planning to do a lot of casting. As far as green sand goes, I don't think it's in the same league as the later technologies, I can understand why your foundry guy wouldn't want to go back. But we are talking about small backyard foundries, not commercial operations, and green sand is cheap and produces acceptable results IF you mull it properly and get the moisture content right.
My point is quite simple, for a small backyard foundry, forget green sand and buy a bucket of petrobond.
30th Sep 2010, 11:55 AM #23Golden Member
- Apr 2008
- Canberra
- 805
I agree with Ray, just get Petrobond. I bought a bucket of it a year or so ago and at the rate im using it hobby casting i'll still have it 5 years from now. Its awesome stuff.
30th Sep 2010, 06:49 PM #24Golden Member
- Mar 2010
- Nth Qld
- 687
One thing that counts against using the urethane three component resins is that the cross linker additive ages rapidly so you don't get much shelf life. The only reason I use it in preference to other methods is I can get it as I need it in small quantities without buying 50 odd litres of the stuff. That said it's great to stuff to use.
30th Sep 2010, 08:56 PM #25I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Slightly off topic for a moment, but since you guys seem to have played with metal casting a bit - how much of a smell is created when you're melting down a bunch of aluminium or cast iron (if anyone has something hot enough for iron)? I wouldn't mind having a play sometime, but I have a suspicion that molten aluminium might create enough stink for the neighbours to object....
1st Oct 2010, 12:10 AM #26
1st Oct 2010, 07:40 AM #27Golden Member
- Apr 2008
- Canberra
- 805
The only offensive smell youll get is if your using one of those waste oil burners that are described around the place. They reek badly, and could easily offend you neighbors/street.
Brendan
1st Oct 2010, 09:12 AM #28Golden Member
- Mar 2010
- Nth Qld
- 687
The rocket engine roar of a gas burner is likely to attract attention, especially if you manipulate the gas valve to get the furnace to light with a spectacular boom. Resin bonded sand does stink as the liquid metal chars it and there's white smoke as well. I don't know about the other casting methods but I'd imagine there's smoke at least.
1st Oct 2010, 07:41 PM #29I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
I think I'd get away with the noise of the burner, I've indoctrinated them all pretty well on the usual noises (grinders, hammers, compressor etc), but smoke could be a problem... How much smoke are we talking, and is it a prolonged sort of thing, or only for a few seconds?
1st Oct 2010, 07:52 PM #30Golden Member
- Mar 2010
- Nth Qld
- 687
