Results 1 to 4 of 4
Thread: Making rivets with a lathe
26th Mar 2023, 09:33 PM #1Most Valued Member
Found this video showing how to make your own rivets, using a lathe.
https://www.youtube.com/watch?v=wctn0Pj2SFk
HTH
27th Mar 2023, 05:12 PM #2Most Valued Member
- Healesville
- 2,129
Kryn I reckon they would be ok for clevis pins but don't think that i would trust the friction formed head for a rivet.
I would like to know what materiel he used for the anvil, if that is what its called?
27th Mar 2023, 11:10 PM #3
I figure that the video explains itself well, you need to remachine the form every two or three rivets, and you need to tighten the drill chuck by belting the key with reasonably heavy hammer (wheel wrench by the look of it). Definitely stressing a lathe more than it was designed to handle, possibly OK if you have an old machine too clapped out to do any accurate machining with, but not a well regarded task for a precision machine that you have obtained after desiring it for quite a few years.
3rd May 2023, 04:44 PM #4
I understand that this is how to make rivets with a lathe. I am sure that looking real hard there must be a video showing how to make rivets with a pushbike, or a tomato stick. All valid points.
If anyone is interested, here is how you make a real rivet. Strong and cheap with almost zero technology.
Almost zero ... yes, the forge can be replaced by Oxy acetylene, oxy propane and even MAP.
The anvil can be replaced by (gasp seriously?) by a peace of rail ... there, I said it. Need to recover now ...
Once you get the hang of it, I bet you can beat that pitiful lathe pseudo rivet making hands down ...
Civilized man is the only animal clever enough to manufacture its own food,
Barry Groves
Making right hand lathe tools
By FinnoUgric in forum METALWORK PROJECTSReplies: 0Last Post: 6th Oct 2022, 02:37 PM -
Making a stand for a small flatbelt lathe.
By bob ward in forum METALWORK GENERALReplies: 7Last Post: 17th Feb 2022, 12:29 PM -
Making lathe chuck soft jaws?
By nigelpearson in forum METALWORK GENERALReplies: 16Last Post: 24th Dec 2021, 06:58 AM -
Homemade lathe in the making?
By gazza2009au in forum TRAILERS & OTHER FABRICATED STUFFReplies: 145Last Post: 29th Apr 2020, 12:55 PM -
Making a lathe compound slide for the mill
By KBs PensNmore in forum METALWORK GENERALReplies: 0Last Post: 17th Jan 2020, 02:14 PM
