Results 1 to 10 of 10
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,594
    Default The hoisty thing
    As per my metalwork project post, here is the redundant hoist.
    As the finely drawn sketch says - 1.3m travel on the chain, and total weight is around 8.2kg. The crank has a weird friction clutch on it that means even if you have a heavy load on the hook, it stays put until you start cranking.
    For those with a knowledge of SA history, this came from Redwood machinery, buried in the back shed - I had to hunt for the handwheel as it had been separated for some reason. The chain runs down the boom and then the leg, so the blue frame it is mounted on has a hole in it to let the chain hang (I added a small counterweight to the end to help it run)
    You get everything from the black block up - that block is fixed and the hoist swivels 360 degrees around that. I'm looking for $120 for it.
    May 2020
    Willowbank QLD
    553
    Hello Michael
    Does this happen to come into 2 pieces. For example the arm that heads up at around 45 degrees, is it easily removable, it looks so in the photo. The weight would be good to pack in a bag for air travel but the arm that is sticking out would make it troublesome. If it does I am keen. I would not be able to pick it up until between May 8th and 16th. If you want it out of your shed earlier I could arrange to have it picked up.
    Thanks Steve
    Sep 2008
    Riddells Creek, Vic.
    850
    Is that the same as the “Skyhook” which is made in America? It looks very similar maybe with another brands label attached.
    May 2020
    Willowbank QLD
    553
    For full visibility for all viewers I have sent a PM to Michael saying I would like to buy if we can sort out pickup. Hopefully we can and I get a new crane. If we do I will message on here for full transparency.
    May 2011
    Murray Bridge S Aust.
    72
    5,988
    Hi Steve, at work, some of our products go to Queensland. I could try to find out if anything is going that way or near to you, so that it maybe closer to collect, if it helps?
    May 2020
    Willowbank QLD
    553
    Thanks for the offer. I will be visiting my daughter in 5 weeks time and she lives about 15 minutes from Michael. If it breaks down I will just put it in my bag. If not I may contact you and see what we can sort.
    Aug 2006
    1,106
    Looks very similar to the Sky Hook.
    https://www.machineryhouse.com.au/a358
    Sent from my SM-N986B using Tapatalk
    Oct 2011
    59
    6,594
    Looks like it's yours Steve -
    Better bring your best towels to wrap it in (I'm sure the better half will quite understand...)
    It's a UK product I think. Given its age, it could well be that other brands have copied it.
    May 2020
    Willowbank QLD
    553
    Thanks very much Michael. I will PM to sort payment and pickup options. Yes I have all ready mentioned it to the better half. Understand luckily has a broad meaning, but after 30 plus years I think she is used to what I pack into a big duffel bag. She seemed to thing postage was practical but why post when you can carry.
    Mar 2011
    Southern Flinders Ranges
    1,569
    Damn.. that would have been more than a bit handy
  1. Another what is this thing?
    Last Post: 15th Nov 2018, 03:50 PM
  2. Anyone know what this thing is?
    By Com_VC in forum METALWORK GENERAL
    Last Post: 14th Oct 2018, 02:46 PM
  3. What is this thing used for?
    By Pete O in forum METALWORK GENERAL
    Last Post: 7th Oct 2018, 08:50 PM
  4. what is this thing please
    Last Post: 31st Aug 2018, 04:46 AM
  5. This a good thing or a bad thing?
    By Old Hutcho in forum METALWORK GENERAL
    Last Post: 5th Jan 2014, 05:36 PM
