Results 1 to 10 of 10
14th Nov 2021, 02:06 PM #1
Various BRAND NAME welding gear- Kemppi MIG consumables (pt2)
Part 2 - hit picture limit.
Pt 1 available here: https://metalworkforums.com/f223/t20...gear-speedglas
Cleaning out the cupboard and found some gear from the years gone by. Stuff from old jobs and gear I have not used for years, or is obsolete as I have upgraded - so these parts are of no use to me.
Happy to ship, postage extra.
Proposed prices are way better than new prices, with the exception that what I have here is genuine- unlike the resellers offering kemppi 'style' gear.
I've found the original stuff lasts longer than reproduction gear. So grab yourself a bargain if it is of use to you.
Kemppi Parts
Most of this was from an old Kempomat 2500 I was running years ago.
FWIW the kempomat 2500 was the same as the BOC migs from late 90's early naughties. I moved mine on years ago... countless dollars spent on consumables thru that machine over the years, hopefully this will help someone with their unit. Might be a lifetime supply of tips for some of you fellas.
Contact tip dimensions may work with other guns running a M6 or M8 thread tip, just check the numbers work for you.
Genuine Kemppi M8 0.9mm Contact tips:
Kemppi part 9580121, Box of 50ea.
$80+ shipping
Genuine Kemppi M8 1.2mm Contact tips:
Kemppi part 9580124, Box of 47ea.
Same pic as above, different wire size.
$75+ shipping
Genuine Kemppi M6 1.6mm Contact tips:
Box of 41ea. These are a shorter tip, If I remember correctly, this was a fluxcore job in confined space, needing a smaller gun.
Not super common to have big wires thru small 1.6 tips, so priced to move at $35 for the lot.
$35+Shipping
Kemppi Nozzle suit PMT32 torch
Kemppi part number 4295760 (Genuine) - 11 available
$10ea plus shipping, or buy the lot for $90.
Kemppi part number 4294970 (Genuine) - 5 available(suits the M6 tips)
$10ea plus shipping, or buy the lot for $40.Kemppi Nozzle Part 4255530 (genuine) suits MT38 and PMT30/40/50 torch (the big boi) - 8 available
$10ea plus shipping, or buy the lot for $65.
14th Nov 2021, 07:51 PM #2Most Valued Member
- 5,942
Tried to open your pics, but you choice of pic supporter, won't allow me to open them.
14th Nov 2021, 09:36 PM #3
Are they visible to you in the thread though?
They are not linked to the high res versions- just the large thumbnails... so you can't click on them.
They are hosted on Imgur.
Also have 4 of the below items - Kemppi 4265240 14 tooth gear wheel for wire drive - 0-18m/min size.
Once again work on the Kempomat 2500 and BOC of same vintage, plus possibly some other Kemppi units. Bought some spares back in the day, as they tend to chew themselves out occasionally.
$15 each, all 4 for $50.
Pics below???
14th Nov 2021, 10:22 PM #4Most Valued Member
- 5,942
Can't see them in the thread, always seem to have trouble with anything hosted by imgur.
15th Nov 2021, 06:49 PM #5
I don't want this to deteriorate to tech support, but what happens if you attempt to reply with quote, then view / copey-paste the image links into a new window?
I'm hoping it's only you that can't see them.
15th Nov 2021, 08:19 PM #6Most Valued Member
- 5,942
Can anyone else see the pics?
15th Nov 2021, 08:28 PM #7
15th Nov 2021, 08:40 PM #8Most Valued Member
- 70
- 1,511
I see them all.
Nev.
15th Nov 2021, 10:56 PM #9Most Valued Member
- 5,942
OK THANKS, obviously my comp is the culprit.
22nd May 2022, 01:29 PM #10
I've tripped over the box of this stuff once again. Open to offers.
Various BRAND NAME welding gear- Speedglas / Lincoln / Tweco (pt1)
By Commander_Keen in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 22nd May 2022, 01:28 PM -
Welding brass clock gear.
By Lappa in forum WELDINGReplies: 13Last Post: 14th Sep 2020, 03:53 PM -
Welding gear trolley
By jhovel in forum WELDINGReplies: 3Last Post: 29th Sep 2014, 02:21 AM -
ESAB tig torch consumables
By argeng in forum WELDINGReplies: 1Last Post: 14th Aug 2013, 09:07 PM -
Anyone interested in regular US welding gear orders?
By NewLou in forum WELDINGReplies: 6Last Post: 10th May 2011, 08:35 PM
