Results 1 to 1 of 1
14th Sep 2021, 06:43 PM #1Senior Member
- Jun 2016
- 283
FS, Sydney: heavy transformer and output power supply
FS: heavy transformer and output power supply
$40 plus any freight
This was taken off a functioning CNC machine as more power was needed. The 230 VAC transformer has multiple windings:
2 off 115 VAC input
7.5 VAC at 2 A output
12 VAC at 4.5 A
17-0-17 VAC at 2 A
28 VAC at 2.7 A
40 VAC at 4.5 A
127 VAC at 4 A
It has 1.2 m long flexible output leads, a static shield, is approx 160 mm x 80 mm, and weighs ~8.2 kg. Yeah, heavy.
A power supply tray (about 300 mm wide) made for the transformer is also available with it. It features bridge rectifiers and filter capacitors for 52 VDC, 24 VDC, 12 VDC regulated and 5 VDC regulated outputs. Fuses are included on the output lines. Not all transformer windings were used on this tray.
It can be picked up in Berrilee, NSW. If you want it sent, it would probably have to go by courier at your cost as it is a bit heavy.
Roger Caffin
Berrilee NSW
[email protected]
Power supply workarounds
By jcatcmc in forum ELECTRICALSReplies: 11Last Post: 4th Aug 2020, 10:51 AM -
32 Volt Power Supply $20
By Chris Parks in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 29th Jan 2019, 12:30 AM -
modified computer power supply?
By neksmerj in forum METALWORK GENERALReplies: 74Last Post: 3rd Nov 2014, 06:10 PM -
Electrolysis using an old computer power supply
By BobL in forum METALWORK GENERALReplies: 95Last Post: 26th Dec 2011, 11:42 PM -
inverter welder power supply
By buildersboy in forum WELDINGReplies: 13Last Post: 17th Feb 2009, 09:28 PM
