Results 1 to 2 of 2
27th May 2021, 07:18 PM #1Gear expert in training
- 34
- 1,080
(Almost) complete change gear set, 20DP 14.5PA 20-130T
As part of the big cleanout at work, these are surplus to requirements.
Almost complete set of 20DP 14.5 degree PA change gears from 20-130 teeth, 5/8" bore, 3/16" keyway, 16mm wide. The "hub" in the centres of the larger gears is 40-45mm, so could easily be bored out or sleeved to suit whatever you need.
The following gears are missing from the set, but could be made if required:
21, 22, 23, 25, 26, 27, 33, 37, 38, 43, 110
The following are duplicates (some of which could easily be re-cut to fill the gaps):
24, 28, 31, 36, 44, 48, 60
107 pcs total.
These are cast iron (some of the small ones are shop made in steel) and are HEAVY, so pickup only from South Caulfield
Would prefer to sell as one lot, $2500 ONO (current ebay prices are about $40-100 EACH)
PXL_20210526_091641465.jpgPXL_20210526_091635106.jpgGear cutting specialists and general engineers www.hardmanbros.com.au
5th Jun 2021, 10:28 PM #2Gear expert in training
- 34
- 1,080
1500?
All offers considered, better someone use them than them take up space and eventually get binnedGear cutting specialists and general engineers www.hardmanbros.com.au
Unknown lathe gear change set
By Jon.holmes in forum METALWORK GENERALReplies: 5Last Post: 2nd May 2021, 11:12 AM -
Homemade Quick Change Gearbox Complete
By TommyGMachining in forum METALWORK PROJECTSReplies: 8Last Post: 25th Feb 2019, 10:15 PM -
Hercus Change Gear Diameter
By pipeclay in forum THE HERCUS AREAReplies: 7Last Post: 15th Jun 2009, 01:41 AM -
Hercus Change Gear Guard
By pipeclay in forum THE HERCUS AREAReplies: 17Last Post: 2nd Sep 2008, 03:36 PM -
Hercus Gear Change Plate
By John Richards in forum METALWORK GENERALReplies: 3Last Post: 16th Feb 2007, 01:24 AM
