Results 1 to 5 of 5
2nd May 2021, 01:29 PM #1Most Valued Member
- 4,258
SA Free. Various machine mounts and bearing housings.
No interest in a week in the bin they go.
2nd May 2021, 01:56 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
Can I have the isolation mounts please
2nd May 2021, 02:40 PM #3Most Valued Member
- 4,258
5th May 2021, 09:35 PM #4Philomath in training
Richard, do you know what diameter shaft those metal bearing caps are meant to hold?
Might be worth grabbing...
6th May 2021, 12:39 PM #5Most Valued Member
- 4,258
They are a size PP206. We ( the AC industry) usually used them on fan shaft and the bearing usually had a rubber bushing around it to reduce noise transmission and vibration etc etc. Although I do believe you can run them with out the rubber bush by using a larger OD bearing.
I think shaft was in 1" range. But of course you could go 30mm without bush
see rubber bush here
https://robsonlinebearingsupplies.co...earings-fitted
DRO display mounts
By bollie7 in forum METALWORK GENERALReplies: 22Last Post: 21st Mar 2020, 06:38 PM -
Qualos No 1 Intermediate Milling Machine - Not working - FREE
By John T K in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 4th Jan 2018, 04:22 PM -
Free Brown and Sharpe milling machine, Sydney.
By Metalman in forum METALWORK GENERALReplies: 7Last Post: 27th Oct 2014, 01:17 PM -
motor mounts
By morrisman in forum METALWORK GENERALReplies: 3Last Post: 9th Feb 2012, 04:03 PM
