Results 1 to 10 of 10
1st May 2021, 06:31 PM #1Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
SA Free Aero/louvre profile aluminium
I have around 4.5-5m in a couple of 2m lengths and a shorter piece of louvre/aero profile aluminium to find a new home for.
67mm wide
15mm high
Outside radius is 268mm from memory
End return radius is 3.5mm
Left overs from a failed experiment.
Pick up only, no postage, no interest in a week or so it’s going in the next scrap run.
5th May 2021, 09:31 PM #2Philomath in training
Can't think what I'd use it for (a weird looking coffee table?) but that sort of length is enough to be useful for something. I'll take it if no one else has a definite use for it.
5th May 2021, 11:17 PM #3Most Valued Member
- Mar 2011
- 1,555
A man of your talents could build a decent sized electric punkahwallah.
Yours if you want it
6th May 2021, 01:04 AM #4Most Valued Member
6th May 2021, 09:31 AM #5Most Valued Member
- Mar 2011
- 1,555
I bought it to make roof bars with, but over the length required to span the roof of my car it turned into spaghetti.
It did look the business though.
Its actually a commercial louvre profile from Capral
6th May 2021, 12:34 PM #6
How would filling it with two part urethane foam go?
The two liquid mix not squirt can and then seal the ends as it expands.
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
6th May 2021, 01:47 PM #7Most Valued Member
- Mar 2011
- 1,555
The section isn’t really deep enough to hold any significant load across its minor axis as is for the application I had intended to use it for. Truth be told, I was mostly certain of that fact when I bought it, but decided to have a go anyway, without failure there can be no success, or something of that ilk...
Would be an interesting experiment to see if two pack would add the required strength across that axis
6th May 2021, 06:48 PM #8Philomath in training
6th May 2021, 08:08 PM #9Most Valued Member
I reckon Michael could easily whip up a decent punkah out of that section. But I doubt even a man of his talents could produce a punkah wallah from it.
6th May 2021, 10:05 PM #10Most Valued Member
- Mar 2011
- 1,555
Punkah - Wikipedia
You have me beaten on both a technicality and my inability to connect the dots.. I had always thought the operator was a coolie, with the wallah being the movement mechanism, hence my somewhat misapplied use of the term electric punkah wallah. Kind of makes sense really, last time I worked in India, we hired a chai wallah as part of our work crew.
SA Aluminium Drawers FREE
By racingtadpole in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 15th Dec 2020, 12:28 AM -
Model Aero Engine Casting Identification.
By Don@2480 in forum METALWORK GENERALReplies: 3Last Post: 28th Jul 2020, 02:48 PM -
Looking for this aluminium profile
By timpotent in forum METALWORK GENERALReplies: 3Last Post: 21st Apr 2020, 04:06 AM -
model aero engines
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 7th Jul 2017, 12:26 PM -
Wax free, solvent free polishing compound ?
By mike rolly in forum METALWORK GENERALReplies: 10Last Post: 28th Apr 2015, 10:02 AM
