Results 1 to 3 of 3
28th Apr 2021, 08:37 PM #1Member
- May 2012
- Dandenong
- 76
2 x MARS200 MIG/MAG Welders - $150 ono as is (never actually used)
I have 2 x 200A MIG/MAG welders I'm selling as one lot. Long story short I bought one of these early on before I discovered the power cabling limitations of our place, so didn't get to use it at the time, but as I'm a tinkerer, I opened it up to have a look at the construction, and found one of the panel screws was actually touching the board. As it was fairly expensive I contacted the seller, and it was arranged to buy another, and then credit the first. Then the troubles of returning the first started, and as some time had passed I found I now had 2 welders I couldn't use until we rewired.
One is still in the original carton, but I don't know which one needed the panel screw filed back as I don't know if the one in the carton was the newer one or the first one going back.
Exact same model as this one, I'm selling both for $150 ono together as is, (my reasoning that even if both are toast the cabling and connectors are worth something, and scrap value on the copper would be good):
New MARS 200Amp MIG/MAG Welder GAS & GASLESS | eBay
I say as is because I can't really test them in any meaningful way, but the unpackaged one seemed to power on fine and they have never been used, just sitting collecting dust in the shed. These are VERY heavy, I'm guessing they have monstrous transformers inside. No other bits are supplied, just the units and all the cabling/connectors as shown. I don't know if there's any extra bits inside the crate, as it's too heavy to lift out to check.
Pickup from near Mulgrave or Richmond depending on day/time.
28th May 2021, 08:27 PM #2Member
- May 2012
- Dandenong
- 76
Last call for $100 for BOTH MIG welders!
I powered up the one not boxed and it lights up fine, and the gun trigger works fine with the spool motor feed.
29th May 2021, 11:02 PM #3Member
- May 2012
- Dandenong
- 76
thread closed.
MIG welders - which one to buy
By MORRIMATE in forum WELDINGReplies: 14Last Post: 30th Sep 2016, 07:08 PM -
Sub $400 Welders
By smidsy in forum WELDINGReplies: 9Last Post: 5th Jun 2011, 08:57 PM -
Old vs New Arc Welders
By newbyangler in forum WELDINGReplies: 26Last Post: 12th Mar 2011, 04:22 PM -
10 Amp Welders
By Sawmaster in forum WELDINGReplies: 21Last Post: 5th Apr 2010, 04:34 PM -
4 in 1 tig welders
By WelderMick in forum WELDINGReplies: 9Last Post: 5th Apr 2010, 01:17 PM
