Results 1 to 11 of 11
11th Feb 2021, 10:32 PM #1Golden Member
- Dec 2011
- 505
FREE - HAFCO RF-115 Bandsaw 6x4 Sydney
Purchased new about 40 years ago. Now I need the space.
Still works, but it's a tired old saw and probably has substantial wear in the gearbox.
Quite a few parts have been changed over the years, for 'reasons'.
Modified to accept the longer blades currently supplied by H&F,
No motor (but comes with the motor pulley), no vertical cutting table, no belt guard, belt beyond redemption. Dodgy 3 leg stand.
Pick up only.
Bill
12th Feb 2021, 07:48 AM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
Pretty much identical to my late 80’s Porsche branded one.
12th Feb 2021, 11:26 AM #3Golden Member
- Dec 2011
- 505
This was new in '80 or 81 I think.
12th Feb 2021, 02:23 PM #4Most Valued Member
- Mar 2011
- 1,555
If you can’t find anyone local that wants it, I’d be interested
12th Feb 2021, 11:52 PM #5Golden Member
- Dec 2011
- 505
RT you are more than welcome, the bandsaw lived with me in Prospect for a few years so would feel at home, but I'm in Sydney - transport would be killer unless you have someone to take it across.
The stand could come off to shrink the package, but it would not reduce the weight much.
Bill
13th Feb 2021, 09:21 AM #6Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
Have the same one, but no blades. What mod did you do for the blades?
(I think mine takes about 1600mm, but Hafco lists 1645mm?)
13th Feb 2021, 10:59 AM #7Golden Member
- Dec 2011
- 505
I read that 1600mm blade length from the machine plate without wearing glasses!
Let me revise my original wording:
"The photo of the machine plate shows 1638mm blade length, but Hafco no longer sells those blades. Current offering is 1645mm."
When I tried a new blade the idler wheel fouled the housing. To make the longer blades fit I simply ground back the casting to allow the idler wheel to travel a bit further.
The amount needing to be removed was not much, certainly not sufficient to create a concern about the remaining wall thickness. I would have thought an increase in blade length requiring the idler wheel to travel an extra 3.5mm would be no problem, but it was not so. Maybe the blades supplied were a bit longer than 1645mm; in any case modification of the housing was needed to make it fit.
Bill
14th Feb 2021, 11:34 AM #8
I also have same vintwge but a Toolex brand? from Gasweld. Yes shorter blades arpia when in Sydney I use to get mine made up at Henry Bros at BoxHill. Now in QLD get them through CXS.
15th Feb 2021, 09:17 PM #9Senior Member
- Feb 2009
- jilliby nsw
- 111
Hello, sent you a PM
15th Feb 2021, 10:55 PM #10Golden Member
- Dec 2011
- 505
Hi hpa1,
I am in Drummoyne, does that work for you?
Bill
27th Feb 2021, 11:31 PM #11Golden Member
- Dec 2011
- 505
Now gone to a new home.
hafco horizontal bandsaw
By canplaythegame in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 11th May 2020, 08:17 AM -
Anyone with a Hafco BS-4A Bandsaw
By rhamer in forum METALWORK GENERALReplies: 7Last Post: 23rd Aug 2017, 03:11 PM -
Hafco 1998 BS-7L Horizontal Bandsaw wiring?????
By Trewella in forum METALWORK GENERALReplies: 5Last Post: 21st Feb 2013, 10:20 PM -
comments on the hafco BS-5, BS-5S bandsaw
By lather in forum METALWORK GENERALReplies: 7Last Post: 11th Oct 2010, 01:54 PM -
perth hafco metal master bandsaw
By thesupervisor in forum METALWORK GENERALReplies: 12Last Post: 11th Sep 2007, 09:46 PM
