Results 1 to 10 of 10
    Mar 2011
    Southern Flinders Ranges
    1,552
    Default SA Steel fixture plate
    Took this off a machine I sold a while back thinking it would be useful for something on my mill.. two years later it’s still sitting unloved in the corner.
    328x378x17 gridded M12 on 50mm centres, ground flat top and bottom (probably started life as a piece of 20mm plate)
    $50
    May 2011
    Murray Bridge S Aust.
    5,956
    Hi Adam, I'll take it. will wait and see what else you cleanse out of the shed, then pick it up, IF that's OK?
    Mar 2011
    1,552
    I was rather hoping to move it sooner over later. At this point in time I don’t have anything else set aside for market place
    May 2011
    5,956
    OK Thanks. When will you be home from work? Will try to pick it up by the weekend, if you're around.
    Regards,
    Mar 2011
    1,552
    Changed my mind, there’s more stuff to go, have a look at the other ads
    Nov 2017
    Adelaide
    56
    25
    Well, if Kryn doesn't take it, please consider me next in line behind him
    Cheer,
    Creedy
    May 2011
    5,956
    Sorry Creedy, already got a use for it. Started to make one, but got side tracked with other projects.
    Nov 2017
    Adelaide
    56
    25
    Well I had to ask, just on the small off chance that you couldn't use it for some reason,
    Enjoy your new fixture plate.
    I certainly know about distractions and side tracks, my shed projects seem to be endless sidetracks with branches, diversions and deviations
    Creedy
    Mar 2011
    1,552
    Default Offering to next in line
    No arrangement has been made for pick up by KB’s, it has now been offered to the next in line, Creedy.
    Mar 2011
    1,552
    Sold
  1. Bright steel plate??
    By China in forum METALWORK GENERAL
    Last Post: 24th Mar 2018, 12:10 AM
  2. Steel plate for welding table
    By th62 in forum WELDING
    Last Post: 18th Aug 2014, 09:18 AM
  3. Steel plate orientation when cutting on a bandsaw.
    By Jim Ferrous in forum METALWORK GENERAL
    Last Post: 8th Nov 2013, 08:29 AM
  4. Steel Sheet or Plate
    By Metal Head in forum METALWORK GENERAL
    Last Post: 31st Oct 2010, 10:25 PM
  5. Flattening a steel plate
    By WelderMick in forum METALWORK GENERAL
    Last Post: 2nd Jun 2010, 10:21 PM
