Results 1 to 15 of 15
    May 2012
    Dandenong
    76
    Default 350mm Brobo 3PH Cold Saw on stand with castors + 240V 1PH Motor - Not Wired!
    Hi all, this is a really substantial 350mm "F" model Brobo Cold Saw, everything about it is heavy duty. $350 ONO.
    It has a 3PH motor that supports 240V and/or 415V, so it can be re-wired for 3PH directly, or used with a standard 2.2kW VFD in 240V wiring configuration.
    I originally planned to just swap the motor out, and bought a new (and very expensive) heavy duty 240V Onga pump motor matching the RPM but just never got around to it, and likely never will. Motor is brand new but has some tarnish on the shaft end from the shed. Looking back I should have just added a VFD at the time to make things easy.
    I got as far as disconnecting all the 3PH wiring, and started to machine a thin sleeve for the pulleys as from memory the spindle on the new motor is slightly thinner diameter than the original, but virtually anything could be used to pack it out.
    The original 3PH motor wiring has been removed as mentioned, but can be very easily restored with some 4-core wiring (I don't have any sorry), and the Star/Delta wiring is shown on the cover if you wanted to use a VFD instead with this motor. Re-wiring for 3PH is very simple indeed.
    If changing the motor to the 1PH Onga I can supply plenty of cabling to suit. Hooking up the wiring is really trivially easy and very straight forward.
    Happy to sell the saw on it's own as I paid several hundred for the Onga motor and could use it for other projects.
    Saw is bolted to a heavy duty frame that has been attached to a base with castors to make moving it a little easier.
    I really need this to go, so have priced it accordingly a great deal less than I originally paid for the saw. Pickup from near Dandenong.
    Mar 2011
    Southern Flinders Ranges
    1,553
    I’d really like to take it off your hands, but I’m not sure where we currently sit with crossing borders to pick it up. I’ll pm later this evening to see what we can work out once I’ve been through the current requirements
    May 2012
    Dandenong
    76
    I believe coming from NSW is the only restriction, requiring self isolation.
    All other states according to https://www.coronavirus.vic.gov.au/t...stralian-state don't have any requirements and can come and go as they please.
    cheers, Ian
    May 2012
    Dandenong
    76
    As I really, really, need to clear this ASAP, and assuming that most people interested would be connecting a VFD to the original 3PH 2.2kW motor, I'm happy to sell the saw on it's own (without the 240V Onga pump motor I bought) for $200 flat!
    That's a helluva lotta saw for $200, and a fraction of what it cost me!
    All that's needed is to run a mains plug, and cable the VFD to the switch/motor after setting the wire bridges for 240v mode as per the diagram on the housing.
    Easy Peasy!
    Sep 2019
    Nagambie vic
    22
    Pm sent.
    Apr 2012
    Healesville
    2,129
    No gear box, so this must be for cutting aluminium not steel?
    Sep 2008
    Riddells Creek, Vic.
    838
    Yes, I noticed that as well but I did not want to mention it. I hope those that are interested in it realise that.
    May 2012
    Dandenong
    76
    I could be wrong, but so far as I'm aware the Brobo Waldon NF350 (Non-Ferrous) is the Aluminium model, this is the Brobo Waldon F350 (Ferrous) model.
    When I got this one I already had a low rpm cold saw (that I also didn't end up using and sold last year!), so I had planned to use it for aluminium as the guy I bought it off said the blade would be fine for Alu, and had just recently been re-sharpened, but of course I never ended up using it either!
    I do note too that most of the commonly available (non-industrial) cold saws are around the 1300-2500rpm range.
    May 2012
    Dandenong
    76
    Ok, last call at $100 for the saw and the stand before I scrap it for parts as I really need it out of my way!
    I had a look at the blade (which had been re-sharpened just prior to my buying it) and it has the following details:
    Kinkelder HM (Hard Metal from what I can find?)
    6342 NKL
    350 x 3.67
    Apr 2019
    Adelaide
    596
    Howdy. I am looking for a cheap cold saw and this might fit the bill. Where did the discussion get to regarding steel cutting? This one does steel?
    My only issue is being in good old Adelaide so I would need to look into the cost of freighting it from you to a depot over here. Do you happen to know the dimensions and weight?
    Nov 2017
    Geelong, Australia
    57
    2,671
    If Mk1_Oz doesn’t end up taking it I will grab it.
    May 2012
    Dandenong
    76
    Hi Steve, I just replied to Mk1, and if he doesn't take it or respond back it's yours!
    I think the shipping would prove prohibitive anyway for him as it's bloody heavy!
    Do you have a ute or trailer?
    cheers, Ian
    Apr 2019
    Adelaide
    596
    I will step aside and let Steve grab it. I am sure I could get it freighted here but it might end up being a headache. Enjoy it Steve!!
    Nov 2017
    Geelong, Australia
    57
    2,671
    Quote Originally Posted by Mk1_Oz View Post
    Thanks mate.
    Ian - I'll send you a PM regarding pickup.
  15. #15
    May 2012
    Dandenong
    76
    Saws sold and been picked up now thanks all, and another opportunity to meet a great fellow forumite!
    The wife will be happy she can get the mower through the shed now!
  1. Brobo 2 speed cold saw - what type of motor are they
    By OxxAndBert in forum ELECTRICALS
    Last Post: 25th Jul 2020, 06:56 PM
  2. 240V Motor for SG
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 11th Mar 2020, 10:55 AM
  3. Motor hard wired for Y - therefore no delta?
    By StrayAlien in forum ELECTRICALS
    Last Post: 24th Nov 2017, 11:22 AM
  4. Cold saw stand
    By Marc in forum METALWORK GENERAL
    Last Post: 4th Sep 2014, 08:38 AM
  5. VICTORIA BROBO Cold Saw with bench, rollers and stops
    By ersbruce in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 5th Jun 2012, 02:29 PM
