Results 16 to 21 of 21
22nd May 2022, 11:40 AM #16Philomath in training
Still looking to move these things on (nuts, the Scleroscope and the knuckle press). Thought I had a taker for the knuckle press but there was never any follow up from the initial 'I'm interested', and I'd really like that to go as it keeps getting in the way.
22nd May 2022, 07:09 PM #17Most Valued Member
- 70
- 1,513
What is the dimensions and weight of the knuckle press?
Nev.
22nd May 2022, 10:14 PM #18Philomath in training
Roughly 300mm side to side, 400 front to back and then 470 high. That would be a outline dimension for packing as there is a counterweight that swings up when in use. I should mention that the actuating handle is not with it - never got around to sourcing a bit of steel for that, but that is just a bit of bar stock. Weight is 'bloody heavy' my guess is 50kg+. I can just lift it. I'd need to get out in the shed with the bathroom scales.
27th May 2022, 08:40 AM #19Philomath in training
According to the bathroom scales, the press weighs in at 40kg. Not sure how accurate that number is, as those same scales keep telling me that I'm overweight. Still, good enough for freight calculations.
27th May 2022, 06:02 PM #20Most Valued Member
- 70
- 1,513
Thanks. Freight cost would be too much so I will have to pass.
Nev.
27th May 2022, 06:48 PM #21Most Valued Member
Nev, I could get it to Tamworth if that helps at all.
Ignyte Precision Granite Surface Plate 24" x 18" x 4"
By kwijibo99 in forum METALWORK - Machinery, Equipment, MARKETReplies: 10Last Post: 5th Jul 2016, 10:41 PM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
