Results 1 to 6 of 6
Thread: 220mm Cold saw blade
31st May 2020, 07:50 PM #1Most Valued Member
Cold saw blade approx 220mm diameter, selling for $0 plus postage.
May need some attention/sharpening as has surface rust on one side.
31st May 2020, 11:29 PM #2
Kryn,
What’s the dia of the centre hole ?
Would you be willing to post it, at my expense ?
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
31st May 2020, 11:58 PM #3Most Valued Member
Pretty sure that it fits the Brobo machines as it looks the same size. Can confirm hole diameters and PCD of the holes tomorrow for you.
Of course I can post it, which is why I put "selling for $0 plus postage".
1st Jun 2020, 10:23 PM #4Most Valued Member
The main centre hole is 40mm as near as I can measure it, the larger holes, 11mm dia (4 of) 63mm centres diagonally and the 2 smaller holes 8mm dia 56mm centres.
Just remeasured it and it's 225 diameter and has 120 teeth.
HTH
2nd Jun 2020, 12:41 PM #5
That’s will fit mine no probs.
Its an ancient Brobo, single speed with a Viva petrol pump for the coolant.
Im at 2137 here.
If you PM me bank details I will shoot you off some $.
Thanks Kryn
HJimcracks for the rich and/or wealthy. (aka GKB '88)
2nd Jun 2020, 10:12 PM #6Most Valued Member
PM sent.
Cold-cut saw blade adapter flange
By nigelpearson in forum METALWORK PROJECTSReplies: 3Last Post: 21st Nov 2019, 04:13 PM -
Cold cut saw blade - different tooth profiles?
By Moph in forum METALWORK GENERALReplies: 10Last Post: 1st Jun 2019, 09:39 PM -
Which Cold Cut Saw?
By FenceFurniture in forum METALWORK GENERALReplies: 29Last Post: 21st Apr 2019, 09:19 PM -
Cold Saw Options: Triton, Cold Saw, Power Hacksaw
By Jarh73 in forum METALWORK GENERALReplies: 41Last Post: 2nd May 2012, 09:15 PM -
putting a cold saw blade into a timber mitre saw?
By gros21 in forum METALWORK GENERALReplies: 8Last Post: 21st Jun 2011, 11:09 AM
