Results 1 to 7 of 7
Thread: Does anyone run...
8th Mar 2020, 04:26 PM #1Philomath in training
Does anyone run...
Does any one run a coldsaw that would take a 9" blade, or a (horizontal) milling machine with a 1 1/4" arbor.
I have both blade and an assortment of cutters with that bore that arrived in a box of miscellaneous.
Rather than photograph etc and find no one wants them, I thought I'd ask first.
8th Mar 2020, 06:08 PM #2
I have a 1 1/4 horizontal arbor.
Keen to see what you have, pm me pleaseUsing Tapatalk
8th Mar 2020, 07:23 PM #3Philomath in training
The goods
So here is what I've got -
The cold saw blade (at least from the hole pattern that's what I think it is) -
Clockwise from the inserted cutter bottom left (diameter x thickness)-
110x26.7
123x19.7
140x17.4
130x16.9
126x9.6
120x15.9
Clockwise from the big cutter, upper left (Dxt) -
250x4
160x1.63
125x18.14
120, 0.605" radius tooth
120x15.8
120x15.8
Dimensions in mm unless stated. Cutters have surface rust and are in most cases filthy. No guarantees on sharpness. some of the carbide inserts are chipped (but should still cut alright)
Saw blade $30, other cutters $7.50 each and buyer pays postage.
As Dave J asked for the picks, he can have first refusal.
8th Mar 2020, 08:11 PM #4
I'll leave these to someone else, thanks Michael
Using Tapatalk
9th Mar 2020, 08:06 PM #5Most Valued Member
- 2,671
I’m interested in the cutters Michael. How close to 1 1/4” are the cutter bores.
I’ve got a 32mm (1.259”) arbor for my TOS mill...
10th Mar 2020, 07:29 AM #6Philomath in training
Just checked a couple and they are all measuring 31.75 (that is, the imperial 1-1/4") or a few thou bigger. If your arbor is definately 32, I guess a smidge could be removed from the cutter bore to take it to 32.
10th Mar 2020, 10:24 PM #7Most Valued Member
- 2,671
Thanks Michael.
I checked tonight and the arbor is bang on 32mm so the cutters will definitely need opening up a bit. I'm guessing it will be a grinding job...
Assuming I can sort out some reasonably priced freight I'll take them off your hands.
Will PM you.
