Results 1 to 11 of 11
Thread: SA evaporative cooler pump
27th Feb 2020, 12:20 PM #1Most Valued Member
- 4,258
240 volt evaporative cooler pump. New.
Free to someone who can use it.
If its still here next bin collection it will be in there.
27th Feb 2020, 12:41 PM #2Most Valued Member
Pm sent
27th Feb 2020, 04:58 PM #3Most Valued Member
- 4,258
27th Feb 2020, 09:58 PM #4Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
If it falls through message me, I’ll take it off your hands.
28th Feb 2020, 06:59 PM #5Most Valued Member
- 4,258
[QUOTE=racingtadpole;1963691]If it falls through message me, I’ll take it off your hands.[/QUOT
On its way to Simon.
What do you want use an evap pump for.
28th Feb 2020, 09:23 PM #6Most Valued Member
- Mar 2011
- 1,552
Surprisingly enough for its intended purpose.
28th Feb 2020, 09:55 PM #7Most Valued Member
I've got an evap cooler which is getting on. I also know that the pump is a common part that wears out.
Since the price was right it was worth a punt on it of being potentially of use in the future.
28th Feb 2020, 09:56 PM #8Most Valued Member
Don't forget to pm me with the bill!
2nd Mar 2020, 09:41 AM #9Most Valued Member
- 4,258
Was thinking that I might have had another pump that may have suited...but that was the only evap pump I had.
You know they need to be correctly sized to suit the evap cooler...too much water and it can get sucked into the fan with water oroblems in roof...too little and pads dont get saturated enough to have efficient cooling. If you need one I still have an account with suppliers.
2nd Mar 2020, 05:08 PM #10Most Valued Member
- Mar 2011
- 1,552
Last time I replaced one I bought a way too big universal one because it was cheaper than an OEM part by enough to make me cringe. I made a diverter return with a T piece and an old stainless ball valve I had left off something else. Wasn’t overly pretty but it worked well.
2nd Mar 2020, 08:15 PM #11Most Valued Member
- 4,258
You can get get a plastic flow control valve which does the same but at a fraction of price. All it does is restict the discharge....in the old days we used a two piece clamp...2 bits of flat steel which went iether side if flexible tubing and screwed together at each end until you achieved clamp and restricted the flow. The flow valves I speak of are available at hardware stores. The pumps are no overloading so does not matter if you restrict discharge flow...just dont restrict suction.
Washing machine pump as a coolant pump
By BobL in forum METALWORK GENERALReplies: 66Last Post: 9th Oct 2015, 09:25 PM -
Home made TIG torch cooler
By Vernonv in forum WELDINGReplies: 0Last Post: 7th Nov 2013, 09:44 AM -
Oil pump
By Michael G in forum METALWORK GENERALReplies: 2Last Post: 5th Oct 2013, 08:54 AM -
My Cooler Finally!!
By johncar in forum WELDINGReplies: 14Last Post: 9th May 2013, 07:46 AM -
Coolant Pump
By electrosteam in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 5th Nov 2010, 06:25 PM
