Results 1 to 9 of 9
    Feb 2020
    Albury
    58
    90
    Default Welder rectifier (AC->DC)
    Turn you old AC transformer style (Buzz box) welder into DC with this bridge rectifier.
    It is capable of 140A continuous current with repetitive peaks to 700A. Up to 600V
    Here is some reading on AC vs DC welding.
    The box is 300x200x150, with most of the space inside taken up by heat sinks. Weight is about 2kg.
    The guy that built it was using it to weld Aluminium with his AC stick welder.
    It's free to a good home. I'm happy to ship anywhere in AU if you pay for the shipping cost.
    Aug 2011
    4,779
    I was nearly going to make my own version of that. All it requires are bridge rectifiers. The more you gang together the higher the current capability.
    In the end I just bought a DC inverter welder. I went from a 180A welder the size of 2 milk crates weighing 60kg to a 200A welder the size of a shoe box weighing about 8kg!
    Still I would have been interested to see how it went.
    Nice offer BTW!
    7,183
    I was given one a couple of years ago. It was in a large cobweb filled 450 x450 x 200 mm steel plate box and had large Al heat sinks. It was mostly empty but it still weighed a fair bit and took up a lot of space. I pulled it apart as all I wanted were the diodes to make a smaller high current dc power supply. Now I need to look around for a beefy, say 24V tranny.
    Oct 2007
    Alexandra Vic
    69
    654
    You would be better to fabricate a bridge rectifier from 4 discrete diodes that can handle the required currents. Paralleling lower current bridge rectifier modules does not control the current sharing between modules so the device with the lowest losses carries the bulk of the current, and the device with the highest losses carries very little. Eventually the one doing most of the work packs in and leaves the rest to fight it out, and the cycle repeats with the new most efficient one doing all the work etc. Eventually they all die from being overloaded, possibly with less than a second between the first and the last giving up. It's just the way of semiconductors, overload them and they die faster than anything can protect them.
    Mar 2011
    Southern Flinders Ranges
    1,536
    I carted a 27kVA 28V secondary winding transformer off to the skip at work a couple of weeks ago.. No idea what it was used for and can’t fathom any application requiring almost 1000A at that voltage.
    Aug 2012
    Greenmount, W.A.
    70
    272
    Good Evening,
    I will take it off your hands - if it has not already gone.
    I will use it to produce a 24 volts DC supply to drive some DC motors I have. They will be powering a tapping chuck in an old drill press I have. Voltage regulation - I can still remember how to do it, as I too was once an electrical engineer - but it is fading fast!
    PM about to be sent.
    Regards,
    Alan.
    Jul 2007
    332
    As a guess 28v DC is commonly used in the aviation industry at least, as a ground power source and if the amperage rating is high, then engine starting probably. Alan.
    Mar 2011
    1,536
    Wrong industry. Aircraft are not normally the sort of thing I see underground.
    Aug 2011
    4,779
    Quote Originally Posted by malb View Post
    Hi Mal,
    Yea that's correct. I had forgotten about that. So the component that carries the higher current gets hotter and then further reduces it's resistance further increasing the current flow. A thermal runaway until the magic smoke comes out!
  1. QUEENSLAND Cig welder transarc tradesman HD (stick/arc welder) 3phase
    By dkaoffroad in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 8th Jun 2013, 10:45 AM
  2. best welder for Gal?
    By Danger Mouse in forum WELDING
    Last Post: 14th Feb 2012, 06:31 PM
  3. Which mig welder??
    By DR ZOIDBERG in forum WELDING
    Last Post: 17th Aug 2011, 03:15 PM
  4. New welder!
    By stiffman in forum WELDING
    Last Post: 8th Aug 2011, 02:07 PM
  5. WTB Mig Welder
    By Joe2601 in forum WELDING
    Last Post: 25th Jul 2011, 12:10 AM
