Results 1 to 3 of 3
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Default 20A 3 phase plug
    I bought a motor today that had a cable and (3 phase) plug on it. As I'm going to be using this with a VFD, both of these are redundant to needs. The plug is a 20A 4 pin Clipsal item (older style), and the flex is a 4 core (3+earth), 2.5m long.
    The motor was out of a bakery so the white stuff you see in the photos is flour and oil/moisture. I was told that the equipment was 3 phase and converted to single via a motor change Probably come right off if you disassembled the parts and put them in the dishwasher. None of the pins look discoloured as if they have arc'd out.
    Any interest for $30 (plus postage if applicable)?
    Dec 2005
    South Australia
    1,657
    I will definitely take it, I will be back in Adelaide on Monday, probably get you post it.
    7,189
    Rather than socket, isn't it a plug?
  1. old whitworth sidchrome socket set ,plus old sidchrome socket bar
    By robyn2839 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 10th Jun 2019, 09:06 AM
  2. Replies: 26
    Last Post: 20th Sep 2018, 07:35 PM
  3. Replies: 0
    Last Post: 27th Jul 2018, 09:12 PM
  4. Replies: 14
    Last Post: 4th May 2012, 08:48 AM
  5. Hercus 3 phase lathe, single phase supply
    By Pete F in forum THE HERCUS AREA
    Last Post: 16th Jan 2009, 10:15 AM
