Results 1 to 2 of 2
Thread: Adjustable hand reamers
12th Jul 2019, 09:57 PM #1Philomath in training
For a long time I've wanted some small adjustable reamers. I finally got some the other day, but as part of the lot there were a whole bunch I already have (and I had some duplicates anyway)
Below in the blurry photo shows the latest acquisition. I'm looking to move all of these on if I can. They are Sutton (M designator), with some smaller ones being Taylor and Jones (H designator). As my existing reamers are also Sutton, I could use them as spares but there may be others out there who would like a reamer or two.
Post is possible at your cost. I will move a bit on price if you want multiples. If you want nearly all of them I'll throw in the yellow box. To give someone who may want most/all of them a chance, I'll hold off on selling individuals until the end of this weekend.
All of the larger ones are engraved (neatly) with the previous company's name. I have not tried but that will probably come off with some sanding as it is not very deep if that worries you. I've called them used if I can see metal particles in the threads of the reamer bodies, and new if I can't. With the exception of one of the Cs with some surface rust, they are all in good condition (the duplicate A, B and C look more battered but are still good). I think it was one of those cases where purchasing a set was attractive 'just in case' but reality was that most did not get used or if so only sparingly
Qty Size Condition Price 1 Tee Handle Used 30 1 HW 9/32 - 5/16(7-8mm) Used 30 1 HY 11/32 - 3/8(8.75-9.5mm) New 30 1 HZ 5/16 - 11/32(8.00-8.75mm) New 30 1 MA7 7 - 8mm. Used 35 1 MA4 9.5 - 10.25mm. Used 35 1 MA3 10.25 - 11mm. Used 35 1 MA2 11 - 12mm. New 35 2 MA 12 - 13.5mm. Used (1 only just) 35 2 MB 13.5 - 15mm. 1 new, one nearly 40 2 MC 15 - 16.75mm. Used, 1 with surface rust 30 1 MD 16.75 - 18.25mm. New 45 1 ME 18.25 - 19.75mm. New 50 1 MG 21.5 - 23.75mm. New 50
As far as I can tell, the case is for a Sutton M3 set (MA4 to MH). Most of the reamers are there; you would only need to find a MF and MH to be complete.
12th Jul 2019, 10:54 PM #2Most Valued Member
That's very tempting Michael. Could you PM me a price for the lot, please.
Thanks,
Reamers
By DSEL74 in forum METALWORK GENERALReplies: 3Last Post: 15th Mar 2018, 10:36 PM -
Hand Scraping a Hand Plane to .0001" Accuracy
By Ulma Doctor in forum METALWORK GENERALReplies: 4Last Post: 28th Feb 2015, 06:38 PM -
Hand taper pin reamers, spiral flute v straight flute
By bob ward in forum METALWORK GENERALReplies: 11Last Post: 22nd Jul 2014, 09:30 PM -
Adjustable Reamers
By jack620 in forum METALWORK GENERALReplies: 15Last Post: 9th Oct 2012, 08:35 PM -
tin snips-left hand or right hand?
By 3 toed sloth in forum METALWORK GENERALReplies: 39Last Post: 18th Mar 2012, 04:07 PM
