Results 1 to 5 of 5
3rd Jul 2019, 04:19 PM #1Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
SA - Powered John Heine 4ft Slip Roll
Greetings,
I have a 4ft John Heine Slip Roll that has had a powered conversion fitted.
Single phase motor coupled to a reduction gearbox to drive the slip roll, operated by a foot pedal.
The unit came from a muffler manufacturer in Brisbane that used it for prototyping.
I purchased it and freighted it to Adelaide and have done nothing with it other than allow it to languish (to the point I haven't even unwrapped the pedal from the unit to test it since purchase, as you see it in the photos is still how it is).
Asking price is $1000 (firm at this stage). If you are in Adelaide metro I can deliver for you if necessary. If you are interstate I can pallet and deliver to the freight company of your choosing (freight is at your expense).
I would also be open to the idea of trading for full or part value on things such as a bead roller, smaller slip roll in the 600-750mm working range, Mitutoyo metric metrology equipment (specifically Mics 25-100mm and DTI's). Site Admin please delete this portion of the ad if not allowed under T&C's.
3rd Jul 2019, 10:57 PM #2Member
- Sep 2008
- lillimur
- 86
I am interested. Do you know what thickness material it will handle?
John.
4th Jul 2019, 12:12 AM #3Most Valued Member
- 5,942
Tried to find out on Google, to no avail. I'd say at a guess that the max over the full width would be about 1mm maybe 1.2mm. You could roll 1.6 but only about 600 wide. These are guesstimates from use about 40 years ago.
4th Jul 2019, 09:43 AM #4Most Valued Member
- Mar 2011
- 1,536
Good question, probably should have included such information in the first place...
It was advertised as 1.6 across full width and a minimum diameter of somewhere around 70mm when I purchased it. I have never used it to verify that though. It also has formers on the ends of the rollers for various sizes of round stock.
Hope that helps
9th Jul 2019, 09:56 AM #5Most Valued Member
- Mar 2011
- 1,536
Sold pending payment and delivery for transport
John Heine 40c rotary shear
By DanielYoung in forum METALWORK GENERALReplies: 6Last Post: 4th Jun 2019, 08:31 PM -
are gmc slip rolls any good?
By jackleg in forum METALWORK GENERALReplies: 1Last Post: 16th Jul 2016, 06:24 PM -
50x14 gauge slip roll
By jackleg in forum METALWORK GENERALReplies: 4Last Post: 16th Jul 2016, 03:30 PM -
John Heine 87A Fly press
By Zsteve in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 20Last Post: 28th Mar 2016, 08:25 PM -
John Heine 200A metal punch/press
By matthew_g in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 14Last Post: 17th Oct 2014, 11:10 AM
